Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
    7th January 11
    Salisbury, MD
    no belt loops on kilt--what to do?
    Hi All,
    Got my first kilt, but it does not have belt loops. What should I do?
    1. Have my wife add in some belt loops?
    2. Wear a belt without using belt loops?
    Also, what size belt thickness should be worn?
    Thanks,
    Don
    DON'T WORRY ABOUT IT. Until I joined this website I had no idea that kilts were produced with belt loops and I have been around kilts for all of my life.If it helps to ease your mind, my kilts have not had them. I venture to suggest that most traditional kilts are without them.So its really just a case of some have and some have not, or, what your instructions may be to your kilt maker-------------- should one know about them, that is.
    As to belt width, two/two and a half inches is about right.Too thin looks awful.
    23rd July 08
    Milngavie, East Dunbartonshire, Scotland
    I am probably a latecomer to kilt wearing compared to Jock Scot, I have only been wearing them since 1976, but I can tell you none of my kilts have had belt loops either. As Jock says, don't worry about it. Your kilt isn't going to fall down.
    I usually wear a kilt without a belt anyway, as I wear a waistcoat, (vest to some), and have had no mishap.
    7th January 11
    Salisbury, MD
    belt not necessary
    So, if i understand you guys correctly--- a belt is not necessary.
    8th January 08
    The Bayou City - Houston, TX
    I have several kilts only one or two have belt loops. I never use them for either the kilt or sporran belt.
    Quote Originally Posted by dredrush View Post
    As long as your kilt fits you then a belt is not necessary. If you wear a waistcoat then belts are usually not worn, however some like the look of a belt, with or more likely without a waistcoat and some like that extra tad of security, particularly if they have lost a wee bit of weight.
    3rd July 09
    Canada
    I would opine that Jock is 100% correct, as usual, but this is quite a fraught topic apparently, because the last time I did comment on this sort of thing I ended up being accused of racist bigotry . Anyway, to expand a bit, it seems belt loops are not really necessary or even traditional, but people in North American in particular have come to expect them on a kilt. Amongst the group that have them, there is a community that uses them for the kilt belt, and some that use them only for the sporran chain or strap, plus a faction that ignores them completely. Beliefs are strongly held and it is risky to challenge or comment on each practice. And logically, for us neutrals the only safe compromise is to use one loop for the belt and the other for the sporran.
    7th January 11
    Salisbury, MD
    compromise
    I am a little slow on the uptake sometimes! So, a compromise would be to use the back loop for the belt and the side loops for the sparron strap. Is that what you are saying?
    20th July 05
    Philadelphia
    He's kidding!
    On the last bit only.
    edit: actually - if you must use loops, use the side ones for the belt and the rear for the sporran strap, othersie it might hang improperly.
    but then you said you didn't have loops anyway....so unless you really really want them, dont bother applying them.
    Daft Wullie, ye do hae the brains o’ a beetle, an’ I’ll fight any scunner who says different!
    Kerrville, Texas
    8 Post(s)
    Most traditional kilts that do have belt loops will only have two, both of which are at the back. Methinks he was joking about using one of each for the sporran or belt, as this would look pretty silly.
    I know the USA Casual kilt has a single rear loop and then one on each side, and there may be other makers out there that put them on the sides too. But for most traditional kilts, it'll be just two at the rear.
    I like the belt loops and use them for my belt, leaving the sporran strap to fend for itself. The reason I use the belt loops is because I find my belt will slip up in the rear when I bend or sit if I don't use them. And then I have to constantly check to make sure my belt is in the right place at the rear, which is just silly. So I use the loops and my belt stays put. Your mileage may vary.
  1. What Are the Two Loops on Kilt Belt?
    By Galb in forum Kilt Advice
    Last Post: 6th May 08, 01:13 PM
  2. Belt through loops or over?
    By Standard in forum Kilt Advice
    Last Post: 7th February 08, 10:28 AM
  3. Belt Loops
    By SnakeEyes in forum How to Accessorize your Kilt
    Last Post: 31st January 07, 09:25 PM
  4. Belt Loops on Kilts - Why?
    By MACKAY in forum How to Accessorize your Kilt
    Last Post: 24th July 05, 10:11 AM
  5. UK Belt Loops
    By Galant in forum Contemporary Kilt Wear
    Last Post: 4th March 05, 02:34 PM
