Results 1 to 8 of 8
    19th January 11
    Bryan, TX
    Transforming a sports coat to kilt jacket
    Hello Rabble,
    Any ideas?
    Jeff
    Nothing says, "I love you" like a sporran full of haggis!!
    3rd January 08
    Illinois, USA
    4 Post(s)
    Here are links to a a couple of threads that might be of use to you. You can always use the "search" feature to hunt for more articles that have been written here on XMarksTheScot.
    http://www.xmarksthescot.com/forum/f...-jacket-30726/
    http://www.xmarksthescot.com/forum/f...details-64696/
    http://www.xmarksthescot.com/forum/f...g-curve-22201/
    Member Order of the Dandelion
    4th November 10
    Arizona
    If it's your first time, go cheap. I picked up a 20 dollar jacket at goodwill that fit me like a charm. I decided to just "wing it" and it turned out decent, although the inside looks a bit shabby, but who sees that! Anyhow, i basically pinned it like I wanted it, did the sewing, check it again on, then cut off the extra fabric. Then I did the second side.
    I have a pic if you go to my profile and check my albums.
    I will try to upload close-ups later and show how much fabric I took off.
    Best of luck to ya mate! Always remember, measure twice and cut once.
    [-[COLOR="DimGray"]Floreat Majestas[/COLOR]-|-[COLOR="Red"]Semper Vigilans[/COLOR]-|-[COLOR="Navy"]Aut Pax Aut Bellum[/COLOR]-|-[I][B]Go mbeannai Dia duit[/B][/I]-]
    [COLOR="DarkGreen"][SIZE="2"]"I consider looseness with words no less of a defect than looseness of the bowels."[/SIZE][/COLOR] [B]- John Calvin[/B]
    2nd May 10
    Roseville, California
    The links above will help you with the technical. A few additional stylistic points that I think can help make a DIY look less...welll, DIY.
    1. Make radius cuts to the front of the jacket, not angular ones. Don't over do them. Your jacket will be worn open, and your sporran isn't as big as you'd like to think
    2. Start the radius an inch and a half or so below the bottom of the button, not too close to it.
    3. End the radius an inch or so ahead of the pocket, don't bisect the invisible vertical line of the pocket edge with the radius.
    4. If you cant, or are uncomfortable with, raising the pocket flaps, then shorten them and re-finish the edge/hem on them. A short pocket looks odd enough, but they look worse with a flap the appears nearly as long as the pocket is deep.
    Good luck with your project. Pics when your done!
    1st May 11
    St. Louis, Missouri, USA
    My dad has actually recently done something like this. He kinda winged-it but it turned out pretty good. You could ask Mickey what he did and I'm pretty sure he'll tell you.
    5th November 08
    Marion, NC
    The links in Standard's post above are the all-time must-read for converting a jacket.
    If possible, use a jacket with patch pockets instead of welted ones. Patches are MUCH easier to maneuver.
    --dbh
    14th January 08
    San Antonio, TX
    Of those I have seen on the board to date, two button saxon jackets seem to look best converted to one button kilt jackets, and three button saxon jackets to two button kilt jackets, unless you plan on changing/shortening lapels and moving the lowest button to the top (which seems like a lot of additional work).
    Good luck and remember, pictures or it did not happen. We look forward to your efforts.
    Mickey is offline Oops, it seems this member needs to update their email address
    13th April 11
    St. Louis, MO
    Those links are all you need. I used ideas from them to do my own and I can barely thread a needle without hurting myself. Takes rather little time and is actually very easy to do. Yesterday I picked up a few more jackets to convert, including a tux jacket to turn into something formal. If I can do it, anybody can do it.
    Biggest tip that I can think of is, when you think you have everything measured, marked and pinned, check it over at least two times, then give yourself extra material on folds to correct any small errors. Nothing is permanent unless you cut it.
  1. 3 Button Sports Coat Conversion
    By Hiram in forum DIY Showroom
    Last Post: 19th December 09, 12:47 AM
  2. altering a sport coat to a kilt jacket
    By puddlemuddle in forum General Kilt Talk
    Last Post: 2nd February 09, 09:16 PM
  3. Finding a Coat / Jacket
    By Jimmy the Celt in forum General Kilt Talk
    Last Post: 11th December 06, 07:07 AM
  4. Which kilt coat is best the Prince Charlie or Argyll Jacket?
    By Kiltedmusiclover in forum Kilt Advice
    Last Post: 12th August 06, 01:51 AM
  5. sport coat to alter to kilt jacket
    Last Post: 24th January 05, 12:40 PM
