5th September 08, 02:07 PM
the little bits of hem in a properly-made kilt
I thought I might post a few pics about the little bits of hem that are put into a properly made kilt so that nothing sags out from under the bottom of the apron. Tartan is Weathered Douglas, if you're interested. Oh - and this is Lochcarron tartan with one of the turned (tuck in) selvedges that's being discussed in this thread http://www.xmarksthescot.com/forum/d...757/index.html The selvedge is visible, but they did a pretty good job putting it in a good place in the tartan for it to blend as well as it could. But it is unavoidably darker in color than the other blocks. It's also stiffer than the rest of the tartan, so it's hard to turn up a smooth taper.
On the left side of the apron, the point of the deep pleat should be completely hidden, as below (red arrow).
In order to accomplish that, you turn up a little hem tapered from a max of about 1/2" at the point of the deep pleat and tapering to nothing at the edge of the apron and at the lap point of the apron on the first pleat.
On the left side of the underapron, the kilt bottom is also turned up a little to keep the point of the underapron edge from showing below the bottom of the apron. The hem starts about 9" from the edge of the underapron and tapers to about an inch at the raw edge, and the hem is stitched _before_ the facing is folded and tacked.
If you are putting a hem in a kilt, you turn up the hem an extra amount at the point of the deep pleat and along a taper at the underapron edge. Remember that, if you want to hem a finished kilt, you need to open up both the apron and underapron facings, turn the hem up, and then remake the facings.
5th September 08, 02:25 PM
Excellent post, Barb! I saw this done on all my tanks and was wondering why. The kilts I have made myself don't seem to sag, probably because they are new. I'll have to go back and see about putting in tiny hems where needed.
5th September 08, 03:06 PM
5th September 08, 03:24 PM
 Originally Posted by Barb T.
Your book is on its way!
Awesome!
Now.. if I can just find a book on patience..
Hmm.. just noticed this. The kilts I have made don't sag at all when laid out flat. However, I did noticed a little sagging in the edge of the underapron once I put the kilt on my body.
5th September 08, 07:10 PM
Knowing these little details let's one evaluate the quality of a kilt and it's maker. We become better educated "kiltsumers". Thank you Dr. Tewksbury!
5th September 08, 08:37 PM
I knew that there must be a reason for the hemmed section, and now I understand why it is in there. Thanks for teaching me something new today.
Member Order of the Dandelion
7th September 08, 11:57 AM
I'm getting more and more respect for J. Higgins, the maker of my most recent kilt.
16th September 08, 07:13 PM
18th September 08, 01:34 PM
Thanks for the explanation Barb. I have often wondered what these little areas of hemming were for when the rest of the kilt had a selvedge instead of a hem.
19th September 08, 09:02 AM
I raise the outer edge of the under apron pleats at the waist, so there is a triangle of double fabric 1/4 to 1/2 an inch higher than the rest of the top edge of the aprons, tapering down to nothing at the start of the pleats.
Fascinating.
Anne the Pleater
By Barb T in forum Hint and tips from Barb T.
Last Post: 13th May 08, 07:27 PM
By Nighthawk in forum General Kilt Talk
Last Post: 6th February 08, 12:01 PM
By Coemgen in forum Kilt Board Newbie
Last Post: 20th August 07, 07:40 PM
By MacSimoin in forum How to Accessorize your Kilt
Last Post: 5th July 06, 10:33 PM
By Kilted KT in forum General Kilt Talk
Last Post: 16th April 06, 03:49 PM
