Results 1 to 10 of 22
    19th May 11
    Albuquerque, New Mexico, USA
    THE DEFINITIVE WAY TO CLEAN YOUR KILT by Joshua Brown
    I came across this on FB it makes sense and it seems that it's been a couple years since someone addressed this here.
    This is as posted after I cleaned up most of the autospell and other readability issues.
    "THE DEFINITIVE WAY TO CLEAN YOUR KILT by Joshua Brown
    This a great question that is never dwelt upon. As a professional kilt maker, I am an expert on this
    subject! This subject requires possible commitment, so be prepared!
    Now, not only do I make kilts, I also do repairs, AND I promote my cleaning services. For small
    spills, smudges, etc., spot cleaning is the way to go. Vinegar, baking soda, smudge stick by tide and
    a water rinsing is the way to go. But what about when you spill that plate of orange curry on your
    lap, or the fact that you think going "regimental" is somehow "authentic" and has to be done and now
    your kilt reeks of all that backsweat traveling down your *** crack, stewing, then getting absorbed
    into the wool and the stink wont come out...... You need a proper cleaning. So how is this done. You
    can pay me 45$, or follow these instructions.
    First let me tell you - DO NOT TAKE IT TO THE DRY CLEANERS. The chemicals they use will "sheen" your
    wool. When they press the kilt, they will not line up the pleats correctly and repress them
    incorrectly.
    1-you must baste the pleats. For cleaning purposes, you need only baste the kilt pleats at the bottom.
    Here is a pic of a kilt that has 4 rows of basting. This happens when you make a kilt, not for
    washing. You can google how to do this, and for even the most non sewing attributed it is easy and
    takes 10 minutes.
    Fill a bath with cold water and a gentle cleanser. My mother NEVER used woolite... Not sure why, but
    we always used a bar of ivory soap that we would swish in the water.
    2-Lay kilt completely submerged in the water for 1 hour.
    3 drain water and turn shower on and rinse for 15 minutes.
    .4-wring the kilt out as good as you can in tub, then take it outside and drape over chairs to air dry. See Steve's post #5 on this one.
    5-About 5 hours is what it takes. It will be ever so slightly damp which is good for the next part.
    6- place a sheet over bed, ironing board, etc and begin to lay kilt out. It will be aligned as the
    pleats are basted. Take a pillow case and place on top or over the kilt. Press the whole kilt this
    way. The remaining dampness should provide steam enough. DO NOT TOUCH IRON TO OPEN WOOL. Pillow case
    always.
    You are done, and have a perfectly clean and rehabbed kilt!!!"
    slàinte mhath, Chuck
  2. The Following 3 Users say 'Aye' to tundramanq For This Useful Post:
    Terry Searl is offline Registration terminated at the member's request
    13th September 07
    Vancouver Island, British Columbia, Canada
    cleaning a kilt
    Thank-you so much for this valuable information......the part about NOT wearing the Kilt "regimental" makes a lot of sense
    While hand washing is one way to clean a kilt, the chemicals used by dry cleaners today are perfectly safe and do not adversely effect wool.
    I do caution my customers to specify that the cleaner "DO NOT PRESS!" Just clean it and hang it up.
    I have my own kilts dry cleaned regularly. I do not need to baste as they are not pressing the kilt. I have never had a single problem.
    I wear the kilt because:
    Swish + Swagger = Swoon.
  5. The Following 7 Users say 'Aye' to The Wizard of BC For This Useful Post:
  6. #4
    19th May 11
    Terry, if you must go regimental with a wool kilt there are ways to keep you and your emissions off the kilt.
    One is an under kilt - a half slip. preferably made of cotton.
    I also hear of guys basting a liner to the back of the inner apron to handle the drips.
    And Steve, it's nice to know about the new dry cleaning chemicals.
    Being adamant about not pressing is huge as it is really hard to press out the train wreak that they create and repress the pleats where they go. These cleaners are more used to ladies shallower pleated skirts where the pleats splay out from the waist or maybe fell. Deep pleats that stay parallel from the fell down are a bit alien to them.
  7. The Following User Says 'Aye' to tundramanq For This Useful Post:
  8. #5
    Oh, and one big caution and something I always warn my customer about.
    If you do choose to hand wash your kilt - NEVER, EVER wring the kilt. While a kilt is wet it is all droopy and saggy. You can permanently damage the fabric by wringing or twisting or even lifting it unsupported while dripping wet.
    I suggest that you gently step on the kilt while it lays in the bottom of the tub. Then roll the kilt gently in a bath towel. Then get in and walk on the towel. When the towel is wet take it off and hang it up and wrap the kilt in another towel. It is amazing how much water a kilt can hold.
    I would never try to pick up a kilt unsupported while dripping wet.
    The towels will remove enough water that the kilt should be damp but not dripping. Then while still wrapped in a towel for support take the kilt out of the tub. You can then lay it out to dry or neatly drape it on a clothes bar to dry.
    I have had kilt take 2 days to dry after hand washing. Never put the kilt over a heater or any heat source to try to speed this up. Like leather you want the kilt to dry slowly and naturally.
  9. The Following 5 Users say 'Aye' to The Wizard of BC For This Useful Post:
  10. #6
    21st May 08
    I have used a dry cleaner in Vancouver for several years. He's experienced, understands wool and the particular needs of a kilt, doesn't baste and doesn't press. No need to. I don't dry clean in Inverness. Mind you, after every wearing I brush inside and out with a proper clothes brush; my kilts hang where they air nicely.
  11. The Following 3 Users say 'Aye' to ThistleDown For This Useful Post:
  12. #7
    19th May 11
    I kind of cringed when I read that. Part of the reason I brought it here for the real experts to peruse and comment. I have added "See Steve's post #5 on this one." to that step.
    Wool is much like human hair when wet - really fragile and stretchy.
    I have long fine blond hair and learned real early to comb it out gently and to not try to braid it while it is wet.
    Slightly damp is OK.
  13. #8
    When selecting a dry cleaner it is just good practice to ask them what chemical they use.
    There are currently 8 chemicals that can be used. Not all of them are available in all areas. Some are good and some are still to be proven.
    PCE, Perchloroethylene or tetrachloroethylene is the old standard dry cleaning solvent. Around since the 1930's and the most common since WWII this is the one that most people know as the dangerous one as it was the very first chemical branded as a carcinogen.
    Alternatives which you may or may not see are;
    DF200 and Ecosolve are hydrocarbons derived from petroleum.
    Dibutoxymethane going under the brand name SolvonD4 is one of the most widely use alternatives to PCE.
    Liquid Silicone or D4 is more environmentally friendly but much more expensive than PCE..
    Brominated solvents like Fabrisolv, & DrySolv clean faster but can damage some synthetics.
    The opinions on supercritical CO2 are still coming in. Some say that it is superior to PCE in every aspect while some point to the higher cost of the machinery as a down side.
    Glycol ethers like Rynex, Solvair, Caled, GenX and Impress) are becoming more readily available and have shown very good results with very good environmentally friendly effects.
    Modified alcohol under the brand name SENSENE may be the best but is still not widely available in all areas.
    My local dry cleaner recently upgraded their machinery. They now use GenX. The machinery cost was over $500,000.00 Canadian dollars.
  14. The Following 2 Users say 'Aye' to The Wizard of BC For This Useful Post:
  15. #9
    19th May 11
    I have avoided dry cleaning since I was a kid and some good family friends ran a mom and pop dry cleaning business in the 60s.
    They were both going deaf in their 40's. The doctor told them why and they added some good exhaust fans for the hanger rack room.
    The vapors were de-waxing their ears and scarring their ear drums. I figured I didn't really need this odor in my house.
    Local kilt maker Kathy Lare told me her horror story if being put in the hospital from pressing a customers kilt that had been stored with moth balls. She and I go the cedar route for this one.
  16. #10
    Moth balls work because they are made from crystallized naphthalene that evaporates slowly. When stored in an enclosed space they asphyxiate the moth larvae. If stored in an open container the fumes just escape and do nothing but smell up your house.
    Cedar is a really myth filled subject but just know that there are true Cedars and others which are commonly called Cedar but are not Cedars. Of all of these only two, the Eastern Aromatic Cedar, (Juniperus virginiana) (which is actually a Juniper) and Red Cedar AKA Cuban Cedar, or Spanish Cedar (Cedrela odorata) (which is actually in the Chinaberry family) are effective against clothes moths. I have seen all types of woods for sale including Western Red and White Cedar. These do nothing but give off a nice smell in your closet.
    I have even seen California Redwood sold a Aromatic Cedar.
  17. The Following 4 Users say 'Aye' to The Wizard of BC For This Useful Post:
