MacGregor and MacDuff Xmarks advertising information Celtic Croft website Xmarks advertising information Celtic Corner website
Results 1 to 10 of 16
    14th July 12
    St. Paul, Minnesota
    Jacket conversion with EZ epaulettes and pocket
    I've learned a lot from reading various how-tos on this forum and thought it was time to return the favor, if only in a small way. I've had a dark green/black harringbone tweed jacket hanging in the closet that was in need of some serious elective surgery. Through the various posts here I got a rough idea of what I wanted—a kilt jacket with epaulettes and plain cuffs that could be worn out in public without too much embarrassment. First, the finished product.
    My aim with this project was to make the modifications in a way that gave me the look I wanted without overreaching my skill set (I'm still at tailoring 101.) I started with a 3-button jacket because I like the higher collar and there was no back vent to contend with. I also wanted to add the ticket pocket because I like the retro look and for reasons I will explain later.
    The epaulettes
    Many conversions add these by tearing into the shoulder seam, and the result can be quite handsome. However, I didn't want to jeopardize the integrity of the jacket by ripping out a seam I wasn't comfortable in replacing. My solution, tacking on an epaulette in a way that would appear to be an integral part of the jacket rather than an add-on.
    Starting with four pieces of material 2 in. by 7 in. salvaged from the bottom of the jacket, pair two of them with one on top of the other with the outsides facing each other. Chalk a semi-circle at one end. Stitch the two pieces together along the long sides about 1/4 inches in for the edge and along the line you have drawn, leaving the other short end open. Repeat for the other epaulette. Now, turn your epaulettes right-side out and press. The finished epaulettes are 1 1/2 inches wide. Determine the length you want for the final epaulette and cut your two epaulettes 1/4 inch longer. Now open up the seams until you can cut one side 1/4 inch shorter than the other. (Image below is looking at an epaulette from the bottom side.)
    Now, place an epaulette upside down along the shoulder seam facing outward so that 1/4 inch tab of extra fabric lies just inside the seam and sew in place, tight into the seam. Sew the rest of the tab to the shoulder of the jacket. Finally, flip the epaulette right side up and blind stitch the edges in 1/4 inch to camouflage the tab. Finish with a button at the other end. (If you're really fastidious, you will have added button holes. Since my 1953 Singer and I only know one stitch, we just moved on.)
    (Note to self: If you're doing a long post here, do it in pieces. I was automatically logged out last time I tried this.)
    Now the pocket
    First, an admission—it's only a pocket flap. (Then again, it's a common practice, and I've got another sport coat with this feature to prove it.)
    I've always liked the look of a ticket pocket on a jacket, but I added it for a second reason. Stealing a cue from magicians, it adds a bit of misdirection. It draws the eye away from the fact the main pockets seem a bit too low and makes them look more natural—at least to me.
    This has to be done before the bottom of the jacket is closed up.
    Start with a rectangle of sacrificed fabric 1/2 inch wider than the finished pocket and about 5 inches long, making sure the twill pattern matches the front of the jacket. With the outside of the fabric facing you, turn up one of the short sides the height you want your pocket to be and press it against the rest. Now run a seam 1/4 inch in from each side, forming a small pocket. Turn this pocket right-side out and press. The long side becomes the outside of your pocket flap.
    To replicate the welt on the main pockets, turn back the long side along the point where the two sides meet and press. Then run a line of stitches down 1/8 inch from there. Fold the long side back over itself and down the back of the flap and press again.
    Determine where your flap will finally be located and chalk a line where the top of the pocket will be on the front of the jacket. Place your flap upside down and position so the line between the two sides just touches the chalk line and the excess fabric is hanging down toward the main pocket (You did remember to pull the lining out of the way, didn't you?). Baste in place. There's just too much fabric here for pins to work well—trust me. Now stitch the flap to the jacket just below that joint line, doubling back at both ends for strength and to lock it in place.
    Pull out your basting stitches, flip down your flap (love that line), and press again. While you're at the iron, you may want to take those 1/4 inch folded over edges and pinch them in toward the center of the pocket a bit and press them in place as well. Finally run a line of stitches in the ditch just below your welt, double back at both ends, and trim your excess fabric below the flap. A bit of fray-check to neaten things up and you're done. If the bit of fabric below the final stitch line shows, you can always add a few blind stitches on each end of the pocket top.
    I chose to add a center button on the ticket pocket, as well as the main pockets, just to finish things off.
    I know—more pictures and less text, but I only decided to make this a DYI half way through the project.
    Good luck on your next project.
    11th August 12
    Upper Ottawa Valley
    Very nice job. Everything looks great together too.
    7th July 09
    Melbourne,Victoria Australia
    Very nice looking jacket, congratulations on the conversion. I think you took the right track on selecting a 3 button jacket to start with and I also like the idea of the ticket pocket, adds that little bit style not often seen. Great job and the style and colour suit you
    7th February 11
    London, Canada
    One of the better conversion jobs I've seen on this forum! Good for you!
    Rev'd Father Bill White: Retired Parish Priest & Elementary Headmaster, lover of God, people (most of them!) dogs, joy, humour & clarity. Theologian, teacher, philosopher, linguist, dreamer, traditionalist, bon-vivant, encourager of hearts & souls & a firm believer in dignity, decency, & duty. A proud Sinclair.
    Fine piece of workmanship there MNlad - you should be proud.
    20th January 12
    The Northern Appalachian Highlands of Southern Ohio
    Nicely done! Very sharp! You have avoided the common pitfalls which present a dead giveaway of an obvious conversion.
    Secretary and Ohio Commissioner, Clan MacTavish USA, Inc.
    1st August 11
    Villa Rica Georgia
    Very nice job - I am going to try that too thank you for sharing it
    19th September 12
    Highland, IN
    Very nice! I think I will try this with some of the material from my tuxedo trousers. Since I had the jacket altered to wear with my kilt, I don't have much use for them anymore.
    19th May 08
    Leucadia CA
    Quote Originally Posted by yodofizzy View Post
    Nice jacket! That looks great!
    Might I ask what those common pitfalls are?
    Lastly:
    How did you do the hem on the bottom of the jacket? It looks very nice.
    Thanks for putting up with all of my questions!
    -yodofizzy
    I do like those epaulettes and the "fool your eye" ticket-pocket flap. To address the "pitfalls" question, I will say that the cut-away is rather sharp -- one of those conversion tell-tales caused by the [perceived] need to not run the edge of the new hem through an existing buttonhole. We've had some discussion here about just making the line go where you want it, especially with a very tweedy fabric. Remove the buttonhole stitching and mend the hole as best you can -- they'll never see it from a galloping horse, and the resulting gentle curve makes the jacket look much more as if it were designed for kilted wear.
    The lowered pockets are another give-away of a conversion, which OP recognized and came up with a novel answer.
    I'd say those two -- front curve and pocket placement -- are the biggies. Anybody else?
    20th January 12
    Many jacket conversions have the pocket patches too low (close to the hem). This is necessary to cover the slashes of the original pockets.
    The other commonly seen issue is a front hem which does not curve smoothly from the bottom button/hole to the horizontal hem of the sides and back of the jacket. A smooth curve is often very difficult or even impossible to achieve, especially when an existing lower buttonhole is eliminated in the conversion. The desired curve often need to transit the old buttonhole, making a clean and properly-curved hem impossible.
