Corduroy X-Kilt
Originally posted by The F-H.C.A.G. on 3/8/07
I am probably going to regret this, but I am answering the challenge inherent in these sentences from Alan H's X-Kilt manual: "Corduroy, well.... I haven't made a kilt out of corduroy yet, so I can't comment. If you make an X-Kilt out of corduroy, let us all know how it comes out."
Went to the store today and picked out the cloth-a charcoal grey medium weight 100% cotton corduroy. The color was per the request of the recipient, an X-marker who shall remain unnamed until the kilt is finished and accepted, at which time, said member can post pictures of the finished product being worn. After today, I am a little more confident that it will eventually be finished, but it's going to take a while.
Here's the fabric, straight from the store, not yet washed
A close up to show how this fabric changes with the angle and the light-it's really nice stuff
I threw it in the washing machine-hot water, plenty of detergent, heavy duty cycle. At this point, I was sweating a little, since the washing instructions on the bolt said "cold wash, gentle cycle", but I figured, if it couldn't stand up to this, it wasn't worth using. Besides, it was on sale for less than $5.00 per yard anyway-I could always start over.
Here's what it looked like right out of the dryer (cotton/high setting). Note that it is not even very wrinkled.
In fact, I did not need to iron it prior to measuring and cutting-it smoothed out well just by shaking it out. Besides, my work surface looked like this.
So, I needed to kick the boy off the table, but he had to finish his homework first.
The complications:
1) I anticipate that when I finally pleat the kilt, I may have a hard time hiding the joins (as Alan H says "...they could buy two yards of the 60-inch wide fabric, cut it in half and sew the halves together, end to end....Well, I'm going to tell you NOT to do that.
Why? Because it's complicated. You can't predict ahead of time where that seam is going to fall, and it's complicated to design the kilt so that the seam is hidden inside the pleat").
2) There is the issue of the knap of corduroy being "one way" as the clerk at the fabric store (and O'Neill-thank you!) pointed out. So, if you join it wrong, it looks "upside down" on part of the kilt.
It is necessary to join fabric when using corduroy, because the lines of the corduroy run the length, not the width of the fabric (if they ran the width, I could follow Alan H's directions to the letter). Unless you can get fabric that is about 140 inches wide, you have to cut sections and join them to get enough to make a kilt. Or, you could make a kilt with the cords running horizontally...which would look very strange, in my opinion.
So, next is how I joined the fabric...
Now, this is a modern kilt and the hem could very well have been machine sewn, but I, as many know, am an anal-retentive, obsessive-compulsive, perfectionist. I did not want this hem to show. So, just as I did with Panache's Stillwater, I blind stitched the hem. This time did not require as much alcohol to cut the boredom, because I was watching Shogun, and because 135 inches is substantially less that the ~250 inches of the Stillwater. I got comfy in my chair, and sewed it up (I finished in about 1.5 hours).
I've only been able to do a little bit today-laid it out and measured. For reference (and I did ask my subject if posting these measurements was OK first): Waist 44", Rump 47.5" (I am using 48"-it's just easier), Fell 6.5", Drop 22.5". Very close to Alan H's measurements actually
Remember, I said corduroy presented some unique challenges? Well it also has one wonderful quality: the lines are already there, so you don't have to worry about chalking a straight line when marking out the pleats. Just mark on the edge and then follow one of the wales/cords/whatever down to the other edge
Here's everything marked-12 pleats (3"), 10" over-apron, fell line (I just marked on the pleat lines-figured this was all I needed to do). Note that my floor is not large enough to lay it all out at once. Also, you may be able to see on the right, that one of the joins is visible, right on top of a pleat. Sigh. Oh well, I was warned, and at least it's barely visible. Also, note the marks for the A-shaping of the front apron.
I'm probably not going to be able to do more today. Hopefully, the chalk won't rub off too much when I roll up the fabric.
AAAUGH! Just had a horrible thought-went back to the kilt, all neatly covered up with cloth on the living room floor and counted the pleats-I only put in 10! Not enough for 48" (10" over apron, plus 10 3" pleats only equals 40"). So I squeezed in 2 more pleats, but that puts the under apron at only 13" (at least I don't need seam allowance since the edge is selvedged). I'm not sure if this is going to be a problem when it comes to modesty? It should be ok, since it is still wider than the over apron. We'll see.
Hmmmm... 3" times 12 pleats plus 10 inches only equals 46" and I need 48", but I figure I can fudge on a few (or all) of the pleats by a bare fraction of an inch and come out OK.
17th May 09, 07:43 AM
By The F-H.C.A.G. in forum DIY Showroom
Last Post: 25th August 08, 10:25 PM
By Racer96 in forum Contemporary Kilt Wear
Last Post: 4th February 08, 01:53 PM
By BozemanboB in forum Show us your pics
Last Post: 8th October 07, 05:59 AM
