13 oz or 16 oz?
Am trying to figure out what I want/need in a new kilt. Will be in Murray of Atholl, wool, and since I only wear a size 32, a 7 yard may be sufficient.
My big question is, how much difference is there in 13 oz fabric as opposed to 16 oz.
There is quite a bit difference in how warm you want to be. I live in Central Florida and ordered my new Seton Modern in the 13 oz. over the 16oz. considering the 90* weather we have here most of the year.
be patient, I'm sure others will chime in with their opinions very soon!
16 oz. Strome weight for sure!
Weasel :ootd:
I'm a fan of 16 oz. strome, too. If heat is an issue for you, consider having it made up into a box pleat kilt by Matt Newsome. They're, beautiful, traditional and made from 4 yds of material. (see link: http://giftshop.scottishtartans.org/...%20pleated.htm)
Living in a similar climate I have to agree with JolyStNicholas on this one. Though, it really depends on what kind of kilt you are getting. 8 yard tank, 5 yard casual, 4 yard box pleat, it all depends. For some types, 16 oz. or heavier is the only way to go for the proper look and hang. Also, wool breathes surprisingly well and in some cases better than other fabrics. So, it really all depends on what your needs and wants are. I am sure with the advice you get here at X Marks, you'll be satisfied with the end result.
A kilt made with 16oz wool will hang better, and the pleats will have more swing (or swish) when walking than a kilt made with 13 oz wool. However, in hot climates, a 13oz kilt will be cooler than a 16oz kilt.
I live in Georgia, and would recommend a 16 oz without hesitation. The heavier wool holds pleats better, is more manageable, wrinkles less in the humidity, is more durable, etc.
It's not really the weight of the wool that creates a feeling of unpleasant warmth in the body as much as it is whether the hose or socks that you are wearing hold body heat or release it. Ask a woman about wearing knee highs. Or talk to people who play in a pipe band.
Add to that the leather belt if one is being worn.
As pointed out in another post.... 16oz Strome is a much better quality as opposed to 13oz I live in Texas and opted for a box pleat from Freedom kilts in 16oz Strome.
– Robert Louis Stevenson
6th June 09, 04:31 PM
I have three 8 yarders. One in 13 oz and two in 16 oz. I've not noticed a real difference in the way they hang or swing. They all look and feel great, so I don't think you can go wrong either way. If hot weather is your concern, then maybe the 13 oz would be best. But, both weights keep me warm in the winter and comfortable in the summer heat.
