29th July 07, 05:28 PM
Before Wear- To Dryclean or Not
I just got my first two kilts, a still water thrifty kilt in Black Stewart and an economy Blackwatch.
My wife is under the impression that i should dryclean the kilts before wearing them to "set" the pleats so that the kilts stay pleated.
Is there anything to this idea or not?
Thanks for the advice.
Nick
29th July 07, 05:34 PM
No need to dry clean them there should have been some care instructions that came with the kilt, the only thing you need do is follow the instructions when the kilt needs cleaning, just make sure to try them on before taking out the basting stitches. And
29th July 07, 05:55 PM
I have 3 Stillwater kilts and the only thing I did before wearing them was to pull out the basting stitches. Also, you don't need to dryclean a kilt that is not made of wool. Just toss it in the wash when needed.
29th July 07, 06:38 PM
I was wearing my SWK MacLeod Hunting standard the afternoon that the box was delivered. When the time has come to lauder it, I simply did it on gentle with Woolite. Line dried and touched up the pleats with a quick steam press.
James
30th July 07, 01:00 AM
James
Me too, I can't even wait for them to be pressed. I put it on the minute I get it and wear it, wrinkles and all, for the rest of the day
There are 10 kinds of people in the world...
Those that understand binary, and those that don't.
30th July 07, 05:14 AM
A dry cleaner will not do anything to the pleats that you can't do at home with an iron and a press cloth. If you're worried about wrinkles from shipping, do the pressing _before_ you take the basting out.
And many cleaners will actually ruin the pressing of the pleats of a kilt because they will lay the kilt down with the pleats fanned before they press. Once a kilt is pressed this way, the back hangs in waves instead of straight down. It's almost impossible to recover from this, unfortunately. You'll see a couple pics below that illustrate the difference between proper pressing and a ruined kilt.
Barb
two properly-pressed kilts
a badly pressed kilt
30th July 07, 06:29 PM
Thanks for the answers and welcomes everyone. It's been a big help.
Nick
4th August 07, 12:22 PM
Barb - That lower flic is just Sad!!! Is there nothing that could be/can be done for this gent???
I don't let the dry cleaners press my kilts !!! I now have a dry cleaner that understands. But I once had one pressed wrong, and I just did the wet pressing cloth routine and all seems well. I cannot look at the back while I'm wearing it, so I'll have the Battle Axe take a shot of me from the rear.
4th August 07, 03:58 PM
wingedferret,
With all the talk of steam, be sure not to use the steam setting of an iron. those temperatures are for cotton and wool only.
Do use a cloth between the iron and kilt, dampening it if you want a little moisture. I believe that using the cloth will protect the finish of the fabric.
4th August 07, 05:38 PM
Also, I've found it's a lot easier to press my kilts on the kitchen table than on a traditional ironing board. Just lay out a bath sheet on the table, then the kilt on top, and, if necisary, use a pressing cloth on top of that.
By taxdragon in forum Kilt Advice
Last Post: 28th July 07, 10:18 PM
By jjoseph in forum Kilt Advice
Last Post: 16th July 06, 06:25 PM
By BLAZN in forum Kilt Advice
Last Post: 19th June 06, 09:57 AM
By michael steinrok in forum General Kilt Talk
Last Post: 26th May 06, 03:36 PM
By David in Maryland in forum General Kilt Talk
Last Post: 16th July 05, 05:46 PM
