14th August 08, 09:14 PM
Belt size
OK, I'm thinking of getting another belt, but I'm kind of debating with myself on this. How small could a belt be for a kilt? I have a 2 1/2" belt and it's a bit uncomfortable to sit down in for a while. I was wondering if I could go smaller, but how much? I don't want a wee belt to hold it up, but I really don't want a huge one.
Would 1 1/2"- 2" do it?
14th August 08, 11:26 PM
According to Thompson So You're Going To Wear The Kilt!, and I agree, it should be 2 1/4" - 3". I think that any less it it looks odd.
Frank
14th August 08, 11:31 PM
Amerikilt sells some nice 2inch belts. Good looking belts, and affordable.
http://www.amerikilt.com/beltsblack.php
15th August 08, 06:12 AM
The key to belt width is visual proportion and keeping everything balanced. On contemporary or casual kilts that are much shorter than a traditional high waisted kilt, it's possible to get by with a narrower belt. I used to wear a 1.75" belt with my USAK casual and it looked just fine as the kilt was about 22" long. When I wear a 24" long kilt 1.75 looks like a piece of string around the waist so to keep the proportions in balance I wear a 2.5" belt. Very tall guys can go up to a 3" belt and stay in visual proportion.
15th August 08, 06:21 AM
SDS, I think something like this would work for you. It's just under 2". These belts are available fairly frequently on eBay and usually at a decent price.
15th August 08, 06:36 AM
I had to go measure my belts after I started reading cavscout's post. I have a brown belt and a black belt that are 2.5". However, I found a 2" black belt at Home Depot. It, like my brown belt, has the two prong buckle and is easy to quickly adjust the size. Ehh, your belt shouldn't really be holding up your kilt... Anyway, those Home Depot, and Lowes belts are around twenty dollars. Hint hint, if you know you are going to be sitting a long time, go to the restroom and loosen your belt a hole or two...
Guess if it is a tab and buckle type belt, there ain't much you can do about it unless you find a way to put a second tab on the belt somehow...
15th August 08, 06:38 AM
I think the belt buckle also has a lot to do with it. If the belt buckle is of significant size, then a smaller belt will still look OK. For instance, I always wore my larger belt up until the time when I bought this belt buckle: This thing measures 4"x3" and takes a 1 1/2" belt, although I am sure I could find a larger belt if I could find one that had a tapered area for where it attaches. But in the end, I was very pleased how it looked with my kilts.
15th August 08, 07:26 AM
What CavScout said, and he knows leather.
One additional comment. Taller people look better (I think) with a wider belt, especially if one is waistline challenged (portly). If you're a bit shorter, then 1 3/4 - 2" will probably suffice. You can look at the Sportsman's Guide website for lots of really cheap military surplus belts that would look fine with a kilt, but you won't find anything wider than about 1 3/4" I think.
Jim Killman
15th August 08, 08:40 AM
I've been thinking of getting of those belts.
15th August 08, 08:41 AM
That doesn't look bad, thanks.
Last Post: 7th July 08, 08:49 PM
By Scotexan21 in forum Show us your pics
Last Post: 23rd January 07, 03:57 PM
By setboy in forum How to Accessorize your Kilt
Last Post: 19th October 06, 11:43 AM
By kilted in KC in forum How to Accessorize your Kilt
Last Post: 17th June 04, 09:32 PM
