19th November 07, 09:42 PM
Belt Sizing
When buying a new kilt belt, what size do you get? Seeing how it sits up higher than a standard belt, do you size it at the natural waist like your kilt and then go up a size?
19th November 07, 11:18 PM
I don't want this to sound wrong but you put on your kilt and then wrap a tape measure around yourself and read the numbers.
Simple.
20th November 07, 06:18 AM
I think Bryan may be wanting to buy his belt at the same time as his kilt, so he can't put his kilt on first. The top of most kilts are worn higher than pants. Close to the belly button area or higher.
This is where you should measure.
When you see kilts worn with the belly flopping over the front, it's because the wearer has allowed the flop-over to happen, and should take the time to pull his kilt up, and tuck his belly in. Having said that, some kilts are designed from the ground up to be worn at the pants level.
Which type of kilt are you buying?
20th November 07, 06:31 AM
My sister, a nurse, told me that this is referred to as Dunlap's Disease..."his belly dun laps over his belt!"!
20th November 07, 06:40 AM
Yep, I suffer from Dunlaps disease! That may be one of the small reasons that I like kilts. I look skinnier in kilts, cause the natural waist of a kilt is higher, and tends to pull my gut in. Also the wider belt of the kilt has more control over the massive gut, that I'm trying to get rid of.
On a side note - do you know that I lost weight on my recent cruise? That only proves that there must be fewer calories in booze than in food, cause I sure did drink my share!
20th November 07, 06:51 AM
Hmmm...a good new diet plan sure to bring enjoyment to many!!
20th November 07, 08:12 AM
My Kilts are 38" I buy 42" belts. Some kilts are thicker than others, and you have to allow for it.
20th November 07, 09:41 AM
I would go with about 4" over the natural waist measurement to allow for adjustment. I wear a 48" kilt and my belts are all around 52"-54". (Hagrid sizing)
20th November 07, 06:36 PM
Thanks for all the replies.
I am expecting a Matt Newsome 16oz box-pleat in the next few weeks.
By Clan Sutherland in forum Kilt Advice
Last Post: 11th August 07, 11:25 PM
By BonnieT100 in forum Contemporary Kilt Wear
Last Post: 2nd October 06, 08:40 PM
Last Post: 26th June 05, 06:48 AM
By MACKAY in forum Professional Kiltmakers Hints and Tips
Last Post: 11th April 05, 03:47 PM
By beerbecue in forum Kilt Advice
Last Post: 17th January 05, 12:36 PM
