28th August 19, 01:03 PM
Bonnet Clan Badge issue - Advise required
Recently received a clan badge for my new Mackie balmoral. The badge attachment is a locking bar pin fastener. The fastener has a lot of play and i suspect it will come unfastened easily. Short of a drop of crazy glue on the fastener itself, does any one have a fix they use for similar problems? i was certain there would be a past thread with helpful advise but after spending some of the morning searching, no joy.
Thanks much
"I know of no inspiration to be got from trousers."
Lt. Col. Norman MacLeod, QOCH, c. 1924
28th August 19, 01:15 PM
If you aren't going to be wanting to remove the badge often, the simplest thing to make sure it is secure would be to just put a couple of small stitches around some inconspicuous part of the badge and through the cockade of the bonnet.
Cheers!
The Following 2 Users say 'Aye' to plaid preacher For This Useful Post:
28th August 19, 02:15 PM
Try a rubber band... Works wonders for kilt pins, and I suspect it would solve your badge problem as well!
http://www.xmarksthescot.com/forum/f...ilt-pin-93610/
SM
Shaun Maxwell
Clan Maxwell Society
The Following 3 Users say 'Aye' to ShaunMaxwell For This Useful Post:
28th August 19, 04:43 PM
Thanks for responding. The rubber band will keep me from losing the badge. Unfortunately, it does not solve the main issue being excessive movement of the rolling catch...thing. The XMTS badge has a locking catch, however my clan badge pin appears to be more cheaply made with no locking mechanism.
Thanks much
28th August 19, 06:06 PM
Just put a dab of hot glue on the catch so it can’t turn.
The Following User Says 'Aye' to FossilHunter For This Useful Post:
28th August 19, 06:34 PM
Had not thought of that. Much less permanent than crazy glue. i know i have a glue gun around here some where. Thanks.
The Following User Says 'Aye' to Jacques For This Useful Post:
28th August 19, 08:07 PM
Sometimes some persuasion with a pair of needle nose pliers can tighten things up. Be careful though...
A. A. Milne
The Following 7 Users say 'Aye' to Liam For This Useful Post:
5th September 19, 06:12 AM
Use a dab of nail polish instead of hot glue.
The Following 2 Users say 'Aye' to Randy McIntosh For This Useful Post:
