Results 1 to 3 of 3
    27th October 11
    Checking the quality of a purchased kilt?
    Hello all, You guys are so helpful with everything else kilt related, I figured there's no better place to figure this out either. I just received my tartan kilt I purchased on ebay, and I now realize that I have no idea if I got a good deal or not. I will say that I'm really liking the Nicholson hunting tartan in person, way better than it looked in the picture, but am wondering on what I can look for, as far as determining if I got what I payed for. It was advertised as an 8 yards 100% wool ex-hire Kilt. the problem is, I have no idea what that should look or feel like. It was purchased from a reputable ebay store in edinburgh. So what should i be looking for. I don't think I got ripped off really, although I will have to get it adjusted a bit. it seems the inner buckle is a couple of inches tighter than the outer one. but other than that it seems nice. I digress, however. So any thoughts? What things can I look for to determine quality? How can I determine the material? I believe there is a tag on the inside that reads Highland wear, but I'll double check that. I'll try to get some pics up later today. thanks in advance. you guys are great.
    14th January 08
    San Antonio, TX
    Re: Checking the quality of a purchased kilt?
    First you can measure the selvedge edge of the kilt (the bottom) from one end of the under apron to the other end of the front apron and add about half a foot to see how much tartan was really used in your kilt. Should be something over 7 yards, give or take a bit.
    Look at the fell---the back of the kilt above the pleats where the pleat edges are sewn together. Topstitching is an inexpensive way of sewing the fell, while true quality machine or handdsewn fells should have essentially invisible stitches holding those sewn and tapered parts of the upper pleats together.
    Check out hte lining to see how well sewn down it is and if it completely surrounds you, and for about 6 inches down particularly over the fell. If you can raise the back of the lining up (which you should not be able to) see if there is a lot of overlapping redundant tartan under the fell---if so they did not cut out the excess fabric from the fell--another sign of shortcuts.
    Did they take the time to line up the tartan pattern in the tabs that hold the buckles with the tartan of the underlying fell?
    Is there a hem on the bottom or a true selvedge (self edge)?
    Is there a reverse pleat at the right hand margin of the under apron? Lacking it is a shortcut and way of saving a bit on tartan needed but makes for a different hang to the first right hand pleat otherwise.
    Lastly, someone here should be able to tell you how to tell wool from PV, which you should verify.
    There are literally hundreds of things to look at in kilt build quality. I am sure others will pipe in with their suggestions.
    Congrats on your first kilt. Welcome to the kilted brethren (and sisters too).
    25th January 11
    "Lastly, someone here should be able to tell you how to tell wool from PV, which you should verify"
    Try burning it... Well a thread of it...
  1. Has anyone ever purchased anything from this site?
    By Tommie in forum How to Accessorize your Kilt
    Last Post: 12th September 08, 08:02 PM
  2. Has anyone purchased from this seller?
    By ncof300d in forum General Kilt Talk
    Last Post: 6th November 07, 08:23 PM
  3. Has anyone purchased one of these?
    By ardchoille in forum How to Accessorize your Kilt
    Last Post: 27th August 07, 08:51 PM
  4. what to look for in a quality kilt
    By shane the piper in forum General Kilt Talk
    Last Post: 30th March 07, 10:28 AM
  5. Quality Kilts 101: Pleat Quality
    By Jimmy Carbomb in forum General Kilt Talk
    Last Post: 28th October 04, 11:11 AM
