Results 1 to 7 of 7
    12th May 08
    Marianna, FL, USA
    Cleaning a kilt jacket at home
    Has anyone tried cleaning their kilt jacket at home rather than taking it to a professional dry cleaner? If so, how did you do it and how did it turn out? I have a Saxon jacket that was converted to a kilt jacket that has been in storage for about 4years and is a bit musty.
    7th February 11
    London, Canada
    What is the material? You mean the ones that say "Dry Clean Only"?
    12th May 08
    Marianna, FL, USA
    I have a suit jacket that I had converted to a kilt jacket. I'm not exactly sure what material it's made out of. It does have a tag that says Dry Clean Only. Someone on Facebook suggested Dryell.
    7th February 11
    London, Canada
    Quote Originally Posted by LANCER1562 View Post
    Without knowing the material, it would be difficult to suggest a cleaning method. Unless you have great confidence in your Facebook source or are willing to forfeit your jacket, I would indeed resort to the cleaners.
    12th May 08
    Marianna, FL, USA
    As the jacket was a thrift store find and hasn't been worn in years, I don't think I'd be losing much. I will look at the tag to see what it's made out of tomorrow and let you know what I find out.
  6. The Following User Says 'Aye' to LANCER1562 For This Useful Post:
  7. #6
    If its just smelling "musty" put it on a coat hanger and hang it from the nearest tree on a couple of dry breezy days and hope.
  8. The Following 6 Users say 'Aye' to Jock Scot For This Useful Post:
  9. #7
    A light spray from an atomiser might freshen it up considerably.
    If there are any marks then a heavier spray using warm water with a small amount of detergent should help - ordinary hair shampoo is good for most fabrics. and pressing an absorbent cloth onto the place should help to draw out stains. Put a pad of cloth against it on the inside before pressing, so you don't push the stain through several layers.
    If there are shiny areas a light going over with a damp sponge should help reduce them - but it should be a very light brushing just to raise the nap.
    These are all techniques used by older generations but they seem to have faded from the memory of most people now that fabrics are so much more easily washed.
    Anne the Pleater
  10. The Following 3 Users say 'Aye' to Pleater For This Useful Post:
