7th August 09, 06:54 PM
Fringe-edge vs selvedge
What is the difference between the two?
Apart from the obvious difference in look. Does somebody have a kilt that is not selvedged. Is the fringe long, short?
If you have 'em, I want to see pictures.
Eric
7th August 09, 08:53 PM
Fringe edge is how the PV material comes form the mill. It's actually a pretty cool look. The only issue I have with it is that the thread they use to "bind" the edge is typically white unless it's a special weave where they've asked for the thread to be another color. The kilt makers that use the PV material will usually offer to put a hem on the kilt if you want.
Here's a pic of my Fraser Hunting Kilt with the fringe. You can easily see the white thread
7th August 09, 09:42 PM
With a wool kilt there is a profound difference between the fringe and the selvedge. Selvedge is the left and right edges of the tartan as it is woven in long lengths, and can be a historically proper kilting edge or a tuck in selvedge. The fringe on a kilt is on the free side margin of the front apron, and can be single, double or even triple fringed, an effect obtained by pulling out vertical threads for about a half inch from what will become the fringe edge.
7th August 09, 10:29 PM
Ok so far, but I mean the bottom of the kilt. Like PV, but made of wool.
Can it be done?
7th August 09, 10:45 PM
8th August 09, 05:22 AM
I remember those pictures, they are the reason for this thread.
Can a wool 8 yard kilt have a fringe edge on the bottom?
8th August 09, 09:17 AM
Whether the fabric you get from Marton Mills has a tucked or fringed Slevedge depends on which loom is next to be set up when your fabric is scheduled to be woven. It's a 50 50 chance unless you very specifically order one or the other.
Does Marton Mills use both looms for both wool and PV? If so, do you have any pictures of PV with a tucked selvedge?
8th August 09, 09:44 AM
The only weaving mill I know of producing a fringed Selvedge is Marton Mills. And then only on their Polyester/Rayon Blend known as P/V.
8th August 09, 03:12 PM
Keep in mind though that just because you are getting a PV kilt, that does not mean it has to have a fringed edge. Marton Mills can produce the PV with a kilt (tucked) selvedge. My American Heritage, Irelands National and Caledonia from USAK all have a kilt selvedge. I personally do not care for the fringe, so I aways call and ask whats on hand in the tartan I want.
8th August 09, 04:04 PM
Just because you asked for it.
Here is a side-by-side comparison of the Marton Mills P/V fabric with both the tucked and fringed Selvedges.
And as others have said if you specify which Selvedge you want as a special order you can get it.
Otherwise it is a 50-50 chance depending on which loom is next up to be loaded.
By Bart_In_A_Kilt in forum How to Accessorize your Kilt
Last Post: 25th January 09, 07:31 PM
By Nick the DSM in forum Kilt Advice
Last Post: 24th December 08, 07:58 AM
By cacunn in forum DIY Showroom
Last Post: 5th March 08, 06:27 PM
By PiobBear in forum DIY Showroom
Last Post: 6th January 07, 09:54 PM
By Kizmet in forum General Kilt Talk
Last Post: 28th June 06, 03:21 PM
