Results 1 to 8 of 8
    21st August 18
    Birmingham, England
    Help finding cotter's pins or bodkin hoppers (military help might be appreciated)
    For my metal kilt jacket buttons, i'm looking for not o rings, but the cotter's pin types.You can see an image here.
    https://m.media-amazon.com/images/I/...AC_SL1500_.jpg
    This is a us navy type, with crimped end so it's not removable from button. That would be the ideal, do you know where these could be sourced?
    Thanks a bunch
    I am not looking for the open ended type if preferable:
    https://www.warsendshop.com/products...-shank-buttons
    Dedge & Skinner might be worth a try.
    30th September 08
    Cypress, Texas
    Button O-ring and clip
    If you can’t find duplicates, you might try these:
    https://kiltsandmore.us/button-o-rin...614OR:len.html
    I use them on my jacket/waistcoat that has interchangeable buttons.
    SM
    Shaun Maxwell
    Clan Maxwell Society
  4. The Following User Says 'Aye' to ShaunMaxwell For This Useful Post:
  5. #4
    21st August 18
    Birmingham, England
    SM
    thanks for the link. I take it that the black retainer pad makes the button sit flatter when viewed from the outside? Does it actually help?
  6. #5
    30th September 08
    Cypress, Texas
    Quote Originally Posted by Kriegbert View Post
    It definitely helps. You notice it immediately on the areas of the jacket where the fabric is thicker. The buttons on the waistcoat have much more play in them until buttoned.
    Jacket buttons from the front:
    Jacket buttons from the back:
    Waistcoat buttons:
    Hope that helps!
    SM
    Shaun Maxwell
  7. #6
    21st August 18
    Birmingham, England
    Waistcoat buttons:
    Hope that helps!
    SM
    Thanks! I wouldn’t have thought of the pads if you hadn’t mentioned it. This reminds me of blazers, which also have a shank button rig. I've only seen the shanks sewn onto the garment like a button would though, which is especially noticeable if double breasted--the left hand side button line droops--it's extremely unsightly to me. They should punch it through the fabric like what you did & have cotters pins; it also gives you the option of interchanging buttons on a whim
    I got the idea for bodkin clutches from evening dress studs--those don’t have retainer pads since the starched linen waistcoat is stiff enough already
    I can see why using the ring would necessitate the plastic disc, since the ring is round. If I can source the long bodkin, since it sits flat across the button, I wouldn’t need it, less fuss!
  8. #7
    21st August 18
    Birmingham, England
    I have contacted tailors before for some other haberdashery materials, but I find that contacting suppliers igets better responses, like richard james weldon or holland & sherry
