Results 1 to 7 of 7
    8th November 06
    Hose in the drier
    Accidentally, one of my favourite hose ended up in the drier, instead of hanging dry. As a result, the detail and texture of the ribbing is bit flat. From a distance, it looks OK, even alongside the sensibly dried partner, but if I look down when I'm sitting, I notice the difference.
    I wonder if anyone has any advice on livening it up again. I'd rather not put the other one in the drier, to bring it down to the standard of the flattened one.
    20th May 07
    Madison, WI
    I can't vouch for this, but you might try hand washing that hose and letting it air dry. It might restore the loft. Unfortunately, quite often machine drying hose will make permanent changes to the qualities if the wool.
    [B][U]Jay[/U][/B]
    [B]Clan Rose[/B]-[SIZE="2"][B][COLOR="DarkOrange"]Constant and True[/COLOR][/B][/SIZE]
    [SIZE="1"][I]"I cut a stout blackthorn to banish ghosts and goblins; In a brand new pair of brogues to ramble o'er the bogs and frighten all the dogs " - D. K. Gavan[/I][/SIZE]
    22nd March 07
    In Doors
    When heated the wool fibers mesh (melt) together. This is known as felting, and is how felt is made. There is nothing you can do to restore them. You might recreate the accendent with the other, so they at least match.
    Frank
    It might be possible to restore the bounce a little using a good sposh of hair conditioner - it smooths the fibres and allows them to separate from eachother.
    Put conditioner into mildly warm water so it is pleasant to work with it, immerse the sock then gently work the liquid through it, splosh squeeze, splosh squeeze. It should begin to feel slithery - if not add more conditioner.
    To improve the ribbing you could work it diagonally, hold the top and bottom of a small section and move one left and the other right, then go the other way, repeat several times then move on to the next section. Draw the ribbing lengthways to finish the treatment, hopefully with sharper ribs.
    With any luck after several minutes of this the yarn will have been unfelted and be more like the original sock.
    Use the conditioner on the other sock - just squeeze it gently in water and conditioner at the same temperature as the first sock, so they don't feel different.
    Hopefully they will once more be indistinguishable.
    Anne the Pleater
    29th March 07
    Edinburgh
    put it down to experience and bin them
    2nd October 07
    I did that once. I kept the hose because they are thick wool and warm, but I can't keep them pulled up because they shrank. They're flat like you described. It really irritates me, too, because they're my navy blue ones, which go best with my Clergy tartan kilt. They look(ed) fantastic as formal wear... but now I have to wear my lovat blue ones until I can replace my navy ones. I feel your pain, man.
    8th November 06
    Anne the Pleater
    Thanks Anne, this certainly has the feel of some splendid, textile-professional advice. I'll give it a try and we'll see how I get on.
    Fortunately, it didn't go a full cycle in the drier, so it's not too bad. I noticed that the load I was about to wash only had one sock in it, and realised fairly quickly what had happened.
  1. Tartan hose vs plain hose
    By kilted Kiwi2 in forum General Kilt Talk
    Last Post: 10th March 09, 01:23 PM
  2. New Hose!
    By Moosedog in forum DIY Showroom
    Last Post: 11th January 08, 09:55 PM
  3. Summer Hose Look, SportKilt $6 Kilt Hose Pushed Down
    Last Post: 20th June 06, 06:33 PM
  4. Who knows hose?
    By eighties in forum Kilt Advice
    Last Post: 27th May 06, 05:36 PM
  5. Hose...
    By Jewddha in forum How to Accessorize your Kilt
    Last Post: 21st March 05, 09:53 AM
