28th July 06, 06:17 PM
I could use some advise please.
I have a new kilt (100% wool) and when I got it, it had the basting stitch in the pleats ya know and when I removed the stitch, it left alittle place there in the pleat. Kind of a folded spot there where the stitch was.
My question is, what can I do about this? I'm thinking maybe wet it alittle and press it with a low heat iron.
I thank you for any help.
28th July 06, 06:21 PM
You could probably just steam it out, but some members with more experience with wool kilts will be able to help you better.
28th July 06, 06:24 PM
It should press right out. Use a cover cloth however. I use a wool setting with the cover cloth on my wool and wool/polyviscose kilts. If the pleats are really crisp you can press some pleats and leave a heavy weight on them while they cool. Come out sharp and hold better. I am by no means an expert and believe my ironing skills are very poor. I still get acceptable results. O'Neille
Hang the kilt up it may just hang out.
If you are going to press it. Lay a heavy blanket on a table spread out your kilt on the blanket. Lay a tea towel over the area you are going to press and give it a bit of steam. Watch that you don't distort the original pressing of the pleat.
28th July 06, 06:34 PM
Not sure where you're at, but if you're Stateside, get you one of them Black and Decker "Gizmos" its a hand steam deal with sort of a duckbill for pressing. Its the best steam blaster I've found...about $30 USD...I just hang my kilts up at the end of the day, blast the wrinkles with the Gizmo (that's the official name) and the wrinkles fall away.
If you have kilts from any fabric, and don't have a Gizmo yet, you're doing WAY too much work with wrinkles and pleats. The duckbill thingie is great for recreasing pleats that have been sat on wrong.
Ron
28th July 06, 07:01 PM
A trick I've used for some time might work. Boil some water in your steam kettle and carefully move the affected area over the jet of steam. This method is most effective on neckties and shirtsleeves. Just be careful not to burn yourself like I did.
28th July 06, 07:57 PM
Ron
I've read posts where you guys rave about these, but never knew quite what you were all talking about. Anyhow, presented the wife with Ron's description here. And alas, her mother bought one for her a couple of weeks ago for the wedding gown. Looks like I just got myself a free ticket to less ironing!!
28th July 06, 08:04 PM
Hmmm, Ron, I did some looking into buying one of the Gizmo Steam 'N Crease irons and found this page on Amazon -
http://www.amazon.com/gp/product/B00...350139-1148615
After reading those reviews, methinks I'll keep looking. You can save a sawbuck at Amazon, if anyone's interested.
28th July 06, 08:15 PM
A full sized garment steamer would be your best bet. I have one and can't do without it.
Search with the words Garment Steamer.
http://www.homedepot.com/prel80/HDUS...4+4370&pos=n08
29th July 06, 06:39 AM
It seems that most of the reviewers got the thing to iron/steam entire garments, and they are right, it isn't good for that. It takes entirely too much time. If I want to do an entire garment, that's why I have the ironing board.
However, I've got one and it works great for touchups. Especially if you just need to press a few pleats that got wrinkled from being sat upon too long. I just hang up the kilt, clamp the Gizmo where it's wrinkled, and give it a short blast of steam.
It's also small enough you could easily throw it into your luggage for touchups on the road. Be sure to drain the water out beforehand though.
