14th August 06, 05:21 PM
I need advice on great kilt
thinking of doing a great kilt.
does anyone have instructions?
would be better if instructions had photos.
thanks
14th August 06, 06:06 PM
I asked the same thing several months ago. I was refered to the following site. It was extremly helpful and answerd the question quite well.
http://www.kalani.net/KiltPleatingB.html
14th August 06, 07:23 PM
 Originally Posted by Southern Breeze
thanx man, I'll check it out
18th August 06, 02:08 AM
Here is another site with photos:
http://www.gaykilts.co.uk/feileadh%20mor2.html
Happy folding
18th August 06, 06:06 AM
 Originally Posted by gilmore
thank you
19th August 06, 02:01 AM
19th August 06, 06:08 AM
19th August 06, 09:58 AM
What is with :
http://www.brotherguido.com/Greatkilt/Default.htm
Lookes like he is doing the pleats the long way???
MrBill
Listen to kpcw.org
Every other Saturday 1-4 PM
19th August 06, 03:07 PM
 Originally Posted by auld argonian
great video thanx, but what happened to the rest of it
19th August 06, 05:53 PM
 Originally Posted by mbhandy
He is a VERY small guy. I've seen that before.
His method would NOT work on 6'1" 200 pound me.
The drawsting method is historically probable:
http://albanach.org/drawstring.htm
Otherwise, many of the methods are pretty much the:
1. lay material on ground
2. put belt wear waist is (slide under fabric)-align to bottom at knee or above
3: hand gather so:
-right apron=1/2 body diameter
-gathered area=1/2 body diameter
-left apron=1/2 body diameter
4. lay down so backside over gathers and belt at waist
5. pull right hand (as laying down) over to left
6. pull left hand apron over right (so top edge is on right hip)
buckle belt
(up to here-> draw string would be easier- slide belt/rope through loops and gather-> make front aprons as above-> put a wide belt over aprons and around waist)
Play with various to arangements to see what like.
A few good ones:
http://www.xmarksthescot.com/forum/s...t=belted+plaid
Also-> tie upper corners together and put behind neck,
pull back up, so makes rain cover
