Results 1 to 10 of 22
Thread: ironing pleats
    30th January 04
    Lincoln County, KY
    ironing pleats
    seriously
    just wondered if you guys spend time ironing pleats? does anyone use a spray starch on their lite-weight kilts for a crisp cut?
    and not so seriously
    http://members.shaw.ca/mikesgenerals...os7/dewar1.JPG
    ambrose
    14th September 04
    London England
    For ironing-go military!
    Blanket on table, lay kilt out so all pleats waist lining etc are exactly in place, with outside of kilt to be ironed-cover with damp cloth-then iron.
    I work fast with a very hot iron and it works well-just make sure that carefully laid out pleats do no get disturbed when ironing. Further keep iron moving, but with a bit of weight behind it-this presses well and ensures kilt not scorched.
    Hang for half an hour before wearing.
    However if you want to survive-do not use partner's highly polished table.
    James
    23rd March 04
    Illinois USA
    Quote Originally Posted by James
    For ironing-go military!However if you want to survive-do not use partner's highly polished table.
    James
    Is that from experience?
    Larry
    "A chef is someone creative enough to call the same soup a different name every day"
    19th April 04
    Kanata ON
    Having read Jimmy's post about ironing, I wonder if one sacrifices the durability of the fabric to have those knife edge pleats.
    Again, paraphrasing Jimmy; don't go near a dry cleaner with your expensive kilts.
    I just took possesion of my wool kilt. It will be interesting to see how this unfolds, or, should I say, does not unfold.
    Casey
    1st March 04
    I agree wholeheartedly with James - but I do two things slightly differently................
    First, I lay the kilt out flat on the floor (carpeted) rather than a table. There's more space to manoever. An ironing board is useless for kilt pressing!
    Second, I leave the kilt where it lies on the floor after ironing until it has cooled thoroughly. Then I hang it.
    Hope this helps.
    24th April 04
    North Dakota
    Ham:
    Something tells me you don't have a cat about the house, a kilt on the floor would be an napping blanket here.
    May all your blessings be the ones you want and your friends many and true.
    1st March 04
    Quote Originally Posted by Bill
    Ham:
    True! No pets, no kids, no wife, no family - all alone!!!
    Spare me the violins - I am happy ..... now!
    22nd January 04
    Southwestern Ontario
    Quote Originally Posted by Hamish
    .... First, I lay the kilt out flat on the floor (carpeted) rather than a table. There's more space to manoever. An ironing board is useless for kilt pressing!...
    I do that as well except I set my ironing board up on the floor keeping the legs folded up under it. The ironing board surface is then just a couple of inches above the floor. This leaves lots of room the lay the kilt out and set up the pleats for ironing on a proper surface. I would still recommend using a pessing cloth to prevent possible damage to the fabric. My iron has a steam "jet" feature which injects steam into the fabric quite effectively. Another trick I've used is to "pull" the heat from the fabric by "ironing" over the pleats again with a cold pot full of ice. This seems to make the crease last longer. Some folks also add a bit of vinegar to the water they iron with. Vinegar is an acid and can corrode unprotected metal parts in your steam iron if left there.
    30th January 04
    Lincoln County, KY
    blu ...
    just to clarify.
    you steam iron using the steam feature on the iron or using a damp cloth and then with a metal container filled with ice water you re-iron...
    and this locks the pleats down? so to speak?
    'brose
    3rd September 04
    Austria / Europe
    i do like hamish although i have cats and girl friend. but every table smaller than the kilt is, makes lot of nervous work.
    i don t move the iron and put a brick on the pleats worked before.
    letting the kilt dry in the ironing position sounds great, i hang it directly before.
