27th April 09, 09:09 AM
Ironing a PV Kilt
I know there is a tutorial. But what about solid kilts? At least with my tartan kilts I have a stripe to matchup/aim for the pleats. DO I need to measure each pleat then bast it? I have a solid saffron on the way and it just hit me like a brick wall. Any thoughts?
27th April 09, 09:14 AM
Iron it before you lose the pleat if possible. Use the previous pleat as your guide.
27th April 09, 10:50 AM
If the Kilt is simply wrinkled they a hanging in the bathroom as you shower or a few passes with a steamer will usually let them fall out.
If the edges of the pleats are not crisp or gone all together the Kilt will need to be re-pressed.
Please note I say re-pressed not ironed. This is a totally different process.
To re-press your Kilt you will need to baste the pleats to get them perfectly aligned, parallel and of the original width.
Basting is easy, quick and quite fun to do. You will need a hand sewing needle, some thread and a tape measure.
I use fairly large needles because I have fat guy fingers. The thread can be almost anything you have around the house that is a contrasting color to the Kilt.
Carefully measure the width of the Pleat Reveal up at the bottom of the Fell. That is at the Hip line where the tapering stitching starts.
Then carry that width down to the Hem and stitch one pleat to the next. Then move on to the next pleat.
Here is the link to Barb T's tutorial on basting.
http://www.xmarksthescot.com/forum/s...ad.php?t=35190
And here is a link to my tutorial on pressing your Kilt.
http://www.xmarksthescot.com/forum/s...ad.php?t=26550
If the answers you need are not here please ask and we'll try to get you the answers you need.
I'll post my $.02 as well (since the PV Saffron he ordered is from USAK).
When we press the pleats in, I press them in pretty hard and pretty firm (and using a gravity feed iron and a vacuum ironing table helps too). When you wash the kilt, the pleats WILL STILL be there (although a bit 'disheveld'). When you layt it flat to dry, STRAIGHTEN THE PLEATS OUT FIRST while damp... it will make ironing MUCH easier.
When you iron, use a steam setting, but a LOW steam setting (3 to 3.5 on an iron that goes up to 5). Also, for Saffron, USE A PRESS CLOTH.
What's a press cloth? A PLAIN COLORED piece of fabric... an old white hankercheif or an old bedsheet cut into a 3" square and doubled up will work very well. When you flip the kilt over and iron the INSIDE (which helps to keep the pleats crisp), you don't need to use a press cloth and you can turn the iron up a little bit (3.5 to 4), but always keep it MOVING over the cloth.
You'll also notice I put a hem in the bottom of the Saffron kilt. When you go to iron the bottom edges, keep the iron either ALL ON the hemmed 2" bottom area or ALL OFF the hemmed bottom area. When the iron stradles the bulkiness of the hem and the 'regular thickness', it tends to heat the edge of the hem too much and give it a 'shine' that you don't want.
When you iron the bottom hemmed edge on the INSIDE of the kilt, you can really push down and steam it to give it a nice crisp edge... but again, keep the iron moving. You don't want it to sit and heat up 1 spot for more than a couple (2) seconds.
Hope this info helps!
Ham used to recommend ironing on the floor, so you're not wrestling with an ironing board.
I just never have to iron my PV kilts - even after washing. Just hang dry then steam with a portable steamer. If you wanna hand the kilt from a door then you can kind of press the steamer vent against the pleat.
What works best for me is just to hold the pleat at the hem. Pull gently so the pleat is sharp, then steam up and down the pleat. Works great.
Rocky's right. He sets those PV pleats well.
Steam, steam, steam.
Ron
hmm
Thanks rocky. I have never owned a hemmed kilt so this will be a learning experience. do you hem all your kilts?
Early on in my kilting career I bought a kilt of man made fibre - it was a total waste of money, but just to put the mouldy cherry on the top of the stale cake, it had been pressed with an iron that was too hot, so the fabric was polished - due to it being melted slightly.
Man made fibres are usually pressed dry - wool required steam pressing, but man made fibres can react badly to it.
Always always put a cloth between the iron and the fabric to prevent polishing the surface. If you polish the outside it looks horrible, but polishing the inside can make the fabric feel prickly against the skin as fibres have been sharpened into chisel edges.
As the kilt is hemmed, when it arrives you can mark each pleat by sewing a few stitches of contrasting thread into the hem only, behind each of the folds. You can then see exactly where to fold the edge even if there are several posibilities. It is a bit of a fiddly job, but you might be glad you did it eventually.
Careful hanging of the kilt after washing also pays dividends, as does preening the pleats during drying to get them into place whilst the fibres are damp.
Anne the Pleater
No... we just got the blind stitch machine about a month or so ago, so we've only hemmed a few. I normally don't hem the PV unless the customer specifies (and usually charge a few bucks for the extra work). However, in this case, the solid color kilts look much better hemmed (vs. the frayed selvedge), so I hemmed it.
Pleater... I'm surprised to hear you say that most man made fibres are dry ironed (no steam). Granted, I don't press ANYthing except kilts that I make and I don't think I own anything else that's synthetic fibre that would require pressing other than my PV kilts... however, the material we use (MM PV) takes very well to a steam iron on a medium setting. I've actually TRIED to 'dry iron it' (when the water to our gravity feed iron ran out and I didn't notice) and it doesn't do NEARLY as good of a job on the same heat setting.
As I said above however, the only thing that's special about the Saffron is you SHOULD USE a press cloth to make sure there's no discoloration or 'shininess' to the fabric.
thanks
Well thanks for the extra work ROcky. I know I have a quality kilt in the mail...it is in the mail?.. ugh the jones hurts. 3 days down.
I too use steam on Marton Mills Polyester/Rayon fabric.
But then again I have an industrial iron as does Rocky. I find that with the steam generated in a seperate boiler it allows me to keep the sole plate of the iron cooler in relation to home irons that rely on the heat in the sole plate to generate the steam.
I too find that the Marton Mills fabrics take steam shaping quite well. Now, these fabrics are basically plastic but I find that they will take a compound curve such as that found in in apron edge tapering. None of my Poly/Cotton or Cotton fabrics will do this at all.
The amount of shaping and molding is not a much as with Wool but amazing if you have ever worked with fibers such as Acrylic.
The Marton Mills Polyester/Rayon blend Tartan fabrics really are in a class by themselves.
I have found that a teflon sole plate will replace a press cloth in almost every instance. I have yet to get a sheen on the fabric using it.
My technique is to use the steam to heat the fabric. Because steam is always the same tempurature the contol is very exact. And becasue the sole plate of the iron is at a lower temp. it is almost impossible to melt the fabric which is what would produce the sheen.
Please note that I said "almost" impossible to melt the fabric. There was that one time when I was folding over a hem of the X Marks Tartan. I had 12 yards double width fabric draped over my ironing table. The excess was in folds on the floor on each side. Then a customer entered the shop. I set the iron up on top of the boiler where it belongs and went to greet my customer. A half hour later I return to my hemming job to find the iron had fallen to the floor on top of 7 layers of fabric. That length of fabric now has iron shaped brown burns every 4 feet of its length and there is a nice iron shaped dark spot in the Fir Flooring.
By shane the piper in forum Kilt Advice
Last Post: 18th March 07, 09:09 PM
By GTRMAN in forum General Kilt Talk
Last Post: 16th May 06, 10:15 AM
By Riverkilt in forum Contemporary Kilt Wear
Last Post: 22nd December 04, 07:35 AM
By awoodfellow in forum Kilt Advice
Last Post: 3rd December 04, 09:26 AM
Last Post: 28th September 04, 11:55 PM
