25th November 06, 12:17 PM
Kilt Belts
I have a question for y'all: how should a kilt belt fit? When I got my kilt about 2 years ago, the sales people cranked down on the kilt and the belt to make it extra snug. Now, having stretched a wee bit (me, not the materials) I find that when I try to put on my belt, the fabric underneath bunches up and the pattern distorts. This is now with the belt at its last hole. I never have found the belt too comfortable to begin with....
Anyway, with the kilt on, I measure 34.5 inches around the belly button. Off, I measure 32. So....what belt size do people recommend and should the wool bunch up underneath?
Thanks ahead of time for any answers.
25th November 06, 01:23 PM
The kilt belt on a Traditional is decorative only. It should be fairly loose. With the kilt cinched, up the belt should be loose enough to move from side to side. If it is so tight that it bunches the kilt, you probably need a larger belt.
25th November 06, 03:00 PM
I disagree when Steve says the belt should be "fairly loose." I've seen a lot of guys wearing the kilt belts way too loose and they slide down the kilt and just look a mess.
The belt shouldn't bee too tight, either. If it's bunching up the cloth of the kilt, the belt is too tight (or more likely, the kilt is too big!).
In other words, the belt should be properly fitting. It should fit snug enough to stay securely in place, but not so tight as to be uncomfortable or distort the look of the kilt.
However, I will say that in all instances I have seen of the belt bunching up the fabric of the kilt, it was because the kilt itself was too big.
As to your original questions, though, I find most belts will have enough adjustment built in that if you just order according to your actual waist size, there is more than enough adjustment to allow for any girth the kilt itself may add.
25th November 06, 03:23 PM
Kilts should be "extra snug" and belts should be quite firm but not so tight as to cut off the circulation of blood. A well fitting (traditional) kilt is nearly like a moderate corset. If its not cut high enough or won't stay put then braces (suspenders) are on call and not a "tight" belt. Belts, has has been pointed out, have other functions than support. If the fabric is bunching up then I suspect that the kilt is not snug enough. I suspect that you still need to "crank down" on the kilt.
25th November 06, 03:45 PM
OK Matt, a case of two versions of the same thought. I like your expanation better.
I guess I've had too many guys in the shop lately that are trying to use the belt to hold up their kilt. I have taken to to showing them that if you grab the belt buckle and try to yank it from side to side, the belt should move but not the kilt.
Thanks for saying what I don't seem to be able to.
25th November 06, 06:24 PM
Crank down the Kilt?
OK, when I crank down the kilt, the belt I have is still too tight and the tartan pattern gets distorted. I did order a new belt from scottishkilts.net that ranges from 32-36 waist line...hopefully this will give me some wiggle room. Anyway, why does the pattern distort when I crank down the kilt? Specifically, the pattern on the apron creates an S-curve distortion on the vertical lines in the set. Any ideas?
Thanks again for all your input so far.
26th November 06, 04:00 AM
Is this a traditional kilt? Made of proper kilting cloth using traditional methods and intended to be worn in a traditional manner? I'm rather confused as the "waist" region of kilts are made to be extremely resistive to distortions, the leather of the straps giving nearly more to belly demands.
Not all, of course, kilts are designed or suited to be worn in the traditional snug manner. Many modern "kilts" are cut lower and some use lighter materials and are intended to hang.
Much of the Sialkot (Punjab, Pakistan) made "traditional styled" budget kilts--- which I do consider reasonable recreational garb (off topic)--- have neither proper waist stabilization nor use an appropriate weave to shape or compress the wasitline. Its rather moot since most don't trim the pleats and only a few even sew them down given the cost sensitive demands of the wholesaler to be able to sell a hand-sewn 8-yard "surprise" material (can be anything from new wool, wool/poly to cotton or viscose blends) kilt at the $25 USD price point--- in Scotland alone the components for straps can cost more.
26th November 06, 05:27 AM
Does your kilt have two straps on the right hip? If so, what is probably happening is that you are wearing that lower strap too tight.
That lower kilt strap serves absolutely no purpose other than to distort the look of the kilt if it is too tight. It simply has no function and certainly does not help the kilt stay on.
If you want to know why it is there in the first place, read my blog post on it:
http://blog.albanach.org/2005/08/why...lt-straps.html
I usually reccomend taking those suckers off!
Aye,
Matt
26th November 06, 07:12 AM
The pucker under the belt can be removed by tightening your kilt another notch, you can also pull a small pucker out of your kilt by pulling both ends of the apron toward the sides or back.
26th November 06, 09:54 AM
I have a bigger belly than you do ozone...much bigger.
Find myself going through a routine proceedure. First I put the belt on and snug it up. Then I add the sporran strap. After the sporran strap is on I find that the belt is way too loose and I snug it up. Sort of like cinching up a saddle on a horse...a two move effort. Maybe its my body adjusting.
I get them wrinkles on my casual kilts so just pull each side of the apron at the same time and it goes away.
For what its worth, I've gone to using the side buckles on the kilts I own that have them, leaving off the belt, and just wearing a sporran...or a vest in lieu of a sporran.
My kilts are a lot more comfy WITHOUT a belt...course that's because of my belly size...but suspect they are for trimmer guys too.
Ron
By Sciuropterus in forum How to Accessorize your Kilt
Last Post: 24th October 06, 07:15 AM
By GMan in forum How to Accessorize your Kilt
Last Post: 7th April 06, 12:06 PM
By Kilted KT in forum General Kilt Talk
Last Post: 6th April 06, 02:07 PM
By Jerry in forum How to Accessorize your Kilt
Last Post: 13th October 04, 04:15 PM
By Chris@southerncelt.com in forum Kilt Advice
Last Post: 27th May 04, 04:32 AM
