Results 1 to 10 of 11
    7th February 08
    Kilt Pin.......Where?
    May I ask, exactly where should the pin be placed on the apron? When is it too high, too low, too close to the edge, too close to the middle, etc? I'm sure there is no exact prescribed placement but would like to hear your learned opinions and preferences. Thank you for your kind assistance.
    26th March 08
    Atlanta, GA
    About 3'' from the bottom, 3'' from the end of the apron is one standard way of doing things. I've never been much on kilt pins, but have worn them on occasion. If I can, I like to find a land mark on the tartan (a nice place where some lines intersect, for example) that's in about the right spot and place the pin over that. It makes the pin look like it belongs there... Just a couple of thoughts.
    Also, I'm sure you've heard it before, but be careful of the kilt pin. Only pin it through the top apron and make sure you don't catch it on anything! My dad's red Ross kilt has a nice rip, from just such an occasion.
    7th April 05
    Frederick, Maryland, USA
    I tend to put mine about 2" from the right edge and about 3-4" from the bottom. What I like to do is place it so that it works with the lines of the tartan.
    14th January 07
    As Ryan says be careful to only put the pin through the top apron. Also, you might want to use a small piece of rubber band, put the pin through the apron, then through the rubber band and then back out through the apron. The rubber band will hold the kilt pin it it comes loose from the bottom clip.
    Place the pin where it look good on you and the kilt. Low and toward the edge. I don't like mine to far to the side. I catch it on things as I walk by. So I put my kilt pin almost in front of my leg.
    7th February 08
    Thanks. That's exactly what I needed. The tip about the rubber band will come in handy too.
    This week end will be the first time I wear my new kilt but I think I've got a pretty good handle on the finer points thanks to the august members of this and the other board. The tartan is Blair modern and the kilt was made by Ann Stewart of the Catskills. This weekend is the Honolulu Scottish Festival and I'll have the Clan Blair Society table there.
    Aloha,
    Bob
    31st December 05
    2 13/16" in and 3 35 64" from the bottom. Takes me forever to measusre.
    7th February 08
    Quote Originally Posted by Frank McGrath View Post
    Jeez Frank.........my ruler only divides an inch into 8th's! You really know how to make it tough on a guy!
    17th November 07
    Winnipeg, Canada
    Youth & Enthusiasm are no match for Age & Treachery
    6th September 07
    Red Deer
    I know the rule of thumb is to only put it through 1 layer, but on windy days, I put it through both. I find it keeps me a little more *ahem* confidential.
    27th May 07
    Leona Valley, California
    Quote Originally Posted by Big Homestead View Post
    On windy days I just wear my 22 oz. Black Watch. It doesn't matter if i wear a kilt pin or not. That apron ain't going nowhere.
