Results 1 to 10 of 13
    20th January 12
    The Northern Appalachian Highlands of Southern Ohio
    Marton Mills wool
    Is Marton Mills wool tartan fabric worsted? Anyone have any experience with its quality? Looks like it is considerably less expensive than Strathmore or Lochcarron.
    16th January 06
    London
    Re: Marton Mills wool
    Marton Mills is a very source of slightly more commerical fabrics, with many different types available. Their Jura range is perfectly good, and am I happy to use it without any quality problems, I do prefer Lochcarron or Dalgliesh ,if i am given a completely free choice, but the Jura range is a good sensible collection . It is a bit cheaper than the others, but over the last year or so the difference is not as great as it used to be. I'd certainly say to give it a go witout hesitation
    8th December 09
    Southwestern Pennsylvania
    Not sure if it's worsted, but it is fine material. I have three kilts in this material, and I'm well satisfied.
    14th January 08
    San Antonio, TX
    MM Jura is worsted the same as basically everybody else's standard wool tartan material. They are a UK but not Scotland based weaver (as is Batley), which IMHO means little. I have several kilts in their Jura range of tartans which, as also described by Nick Fiddes on Scotweb's site, are ever so slightly coarser to the hand than the best Scottish weavers (HOE, Lochcarron, Dalgleish, and Strathmore--I have kilts in tartan from all of them as well to compare to), good depth and breadth of colors, and have a cutoff selvedge, which in most cases is quite good but can be variable in its quality from piece to piece and run to run. I have had no problems with any of the tartan from their mills, and consider it a good product at a reasonable price that will suit the vast majority of folks seeking kilts. They have a long list of available tartans, and their fabric is generally readily available (rarely on backorder for long). From more than an arms length away I think very few people would be able to tell the difference between their tartan and those from the scottish mills. Combined with the breadth of tartans available and cost for level of quality, I think they area great place to start for most folks getting into kilts for the first time but still desiring a traditional wool heavyweight tartan kilt. The rest of us kilt snobs may dote on the color depth or hand or traditional selvedge or available colorways of the scottish weavers, and rightly so, but in all honesty the differences are really only evident to the educated and observant. I think that the heavyweight HOE Nevis class of tartans is of similar quality with similar cutoff selvedge, slightly more vivid colors (IMHO) and essentially comparable in cost, and could be a reasonable alternative depending on your desired tartan and how you fancy the colors available in that tartan. As always, if colors are important to you by all means order some swatches and compare both colors and fabric feel and weight.
    I have not and would not hesitate to order a wool tartan kilt in Marton Mills Jura (or HOE Nevis, for that matter), if that is within your price range and they have the specific tartan you are seeking in colors you consider acceptable. If you do I hope you are satisfied as I have been. Good luck in your endeavors.
    jeff
    BEEDEE's Avatar
    BEEDEE is offline
    8th January 07
    Tinopai, New Zealand
    I have a kilt in MM Jura made by Rock at USA Kilts. It's just fine for me.
    Brian
    20th January 12
    Thank you all for sharing your experiences... very helpful.
    3rd November 08
    Co Antrim
    I have one kilt in a 16oz Marton Mills cloth (Grey Heritage). Very smart, sturdy and uncreasable but a bit more scratchy than my other kilts which are Lochcarron, but wear it all the time.
    John
    30th June 10
    San Francisco, CA, USA
    Quote Originally Posted by John_Carrick View Post
    John
    I agree with you and others who've commented in this vein. I have one also, 16oz Douglas Grey Modern from Marton Mills. I also find that it has a coarser feel than my other kilts, which are all either Lochcarron or Batley fabric. That doesn't make me like it any less or wear it any less, however -- it's a fine kilt and I'd have no qualms about buying/wearing others in Marton Mills wool tartans.
    12th September 07
    Goose Creek, SC
    Marton Mills wool is fantastic for the price in my opinon. My best kilt, hand made by my grandmother, is crafted from the stuff and it is comfortable and sturdy. I say go for it.
    16th May 11
    Tupelo, MS
    Marton Mills makes it possible for the not so rich people (me) to be able to get decent cloth to make a fine kilt from. You can not go wrong purchasing from them.
    A stranger in my native land.
    Kilty as charged.
  1. Isle of Skye: Marton Mills PV vs. Lochcarron 16 ounce Wool
    By Riverkilt in forum The Tartan Place
    Last Post: 20th January 10, 06:14 PM
  2. Marton mills website?
    By Erisianmonkey in forum Miscellaneous Forum
    Last Post: 1st July 09, 05:44 AM
  3. Marton Mills Help!!
    By Sheep In Wolf's Clothing in forum DIY Showroom
    Last Post: 6th November 07, 08:13 AM
  4. County Antrim - Marton Mills 13oz wool
    By BEEDEE in forum USA Kilts
    Last Post: 14th June 07, 08:42 PM
  5. Marton Mills wool/poly tartan
    By Alan H in forum Professional Kiltmakers Hints and Tips
    Last Post: 16th June 06, 11:21 AM
