7th August 06, 07:38 PM
My first kilt.
Well my first kilt has arrived. In my previous post I gave more details but the upshot is I am the best man at a kilted wedding. We decided to go with Royal Stewart because the brides maids are in red. I purchased three Kilts, hose, two belts and sporrans from kiltmart. So here it it:
The jacket and Shirt on not the ones we will be using for the wedding.
Questions:
1) is the belt supposed to go through the belt loops, I ask because it does not seem like it would fit.
2) the sporran seems a little short right?
3) am I supposed to fold the hose back, if so how far?
4) How far is the kilt supposed to drop? My wife likes the current length but I thought it was supposed to be shorter.
Reason: added info
7th August 06, 08:06 PM
First of all, what type of jacket WILL you be wearing? I will go ahead and say that you should not wear a belt full formal. Especially if you're going with a Prince Charlie or Argyle jacket. Make sure you get a much shorter jacket whichever way you go. A standard suit, tux, or blazer coat is simply much too long for a kilt.
The sporran looks to be ok actually.
Yes, the hose should be folded. A couple of inches should do fine. I basically gauge the fold to the pattern changes in the hose.
Kilt drop is sometimes debated. But I, like most people, agree that the kilt should come to the top of the knee. Yes, the kilt will feel like it's too high (navel or even higher) but this is where it's supposed to be. Think of it like this: If you can't see your knees, SOMETHING'S WRONG
Here's a snap from my recent wedding. Click to see larger size...
Also, look through the "show us your pictures" forum. Oh, and Welcome!
7th August 06, 09:00 PM
We will be wearing a Tux waist coat similar to what you have but without the buttons. We will not be wearing vests, nor cumber-buns so that leaves belts.
You say that but it looks to me like yours mostly covers the knees.
Will do at my high bandwidth connection tomorrow.
8th August 06, 11:57 AM
No, my kilt is at the top of the knees. See the skull tattoo there? That's centered perfectly on my left knee cap . I'm turned to the side in this one, so you don't really see a straight forward shot.
8th August 06, 06:35 AM
Wear the belt since you won't have a vest. The belt should be lowered so that about 1" of kilt shows above the belt. THe belt can go thru the loops if you want but many do not use the loops at all.
As the belt comes down so should the sporran. The genereal rule is one hands width between the belt and the top of sporran. I tend to place the sporran height just low enough to keep it off my thighs so it doesn't bounce as much when I walk.
Top of hose is about 2 - 3 finger widths below the bottom of the knee.
I think your kilt could come up about 1" or 2". The narrowness of the knee really makes the look come together in a masculine way.
Will the wedding party be wearing flashes?
Are off-white hose an option? I think those might look better than black.
8th August 06, 07:13 AM
Part of what keeps this stuff interesting is the varying opinions. Here’s my own take on it. You can see some pics of me dressed for formal occasions at www.planopiper.tk.
If your kilt is a traditional one, then those may or may not be beltloops in the back. Either way, they should be plenty big for any belt, so if you think they may be too small then I wonder if your kilt is a modern variation. Those sometimes have smaller beltloops meant for a regular belt. Since you’re asking about how to dress for a fairly formal event, traditional standards apply. The kilt belt should be worn with the top edge along the top edge of the kilt, so no tartan shows above the belt. In that case the belt can’t go through the loops because that would put it too low. On the other hand, with a formal jacket like you’re talking about, no belt should be worn. The kilt should fit well enough to stay up without a belt.
The sporran was originally worn to the side, which makes sense to anyone who thinks about it for a minute. It’s my understanding that it was moved to the front in Victorian times for modesty’s sake, to cover any bulge in the front of the kilt. With that in mind, position the sporran accordingly.
Typically the hose are long enough to be folded over once or twice at the top. I like about a 3 inch fold. The top should be just above the swelling of the calf, or a few inches below the knee. If they’re too short to fold back and still keep the height, then don’t fold them. The fold will be less apparent than the height, so the height gets priority. In your picure they're a little too high. Some people think white hose are better for formal dress, some prefer colored hose. Off white is never formal.
For myself, I think the kilt looks better when it comes just above the knee. I used to think differently, and there are many other opinions about it. The top of the kilt should be very high, at least up to your navel. The position at the top is less important than the position at the bottom because it’s less obvious. In the picture of me on the front page my kilt has slipped down about an inch because I’ve been playing for a while and it’s settled. I should have tightened the straps a little bit.
8th August 06, 07:46 AM
First I would like to say thank you for all the help. I would have been lost without this board, and its easy to forget to say thanks.
Second I will be more specific about the kilt:
Affordable Royal Stewart Kilt #16137
Semi Dress Sporrans #16151
Embossed Piper Kilt Belt + Thistle Buckle #16221
As you can see this Kilt is part of their affordable line rather than a traditional kilt. Looking at the pictures on kiltmart I can see that the belts are not put through the. I think that with the side strap pulled tight it should stay up without the assistance of the large, and apparently for appearance only belt.
I cannot envision wearing the kilt with no belt, cumber bun or vest. Some how that seems like it would look wrong, but then I guess I am just use to wearing a belt with pants. Should I again start pushing for a vest?
I am glad to hear the sporran is about right since its on the last available loop. I may still have a problem though since the sporran is also not currently though the belt loops either, should it be?
I think I will keep the kilt at about mid knee since that will require no alteration to the kilt and once I get the hose folded down correctly it will look closer to correct.
Thank you
Paul Wilson
8th August 06, 07:54 AM
I realize that we went with some inexpensive options which won’t be traditional. The decision was made that having a unified look and allowing the groom to look slightly better was the way to go. As it is the Groom already has to pay for one of the groomsmen’s outfit. From here I am just trying to get it to look as nice as I possible.
I will definitely retry the kilt tonight to get it sorted out. We currently do not have flashes, should we?
BTW: both my wife and my 6 year old daughter like the outfit.
Thanks again
Paul Wilson
8th August 06, 08:04 AM
I would not worry about the belt loops unless you have a problem keeping the belt in place.
To be truely formal I believe you should wear a vest. But I would not go get a vest for this since you already have a belt. Wear the belt, it will look just fine.
Here is a dark grainey pic of the outfit I wore to a wedding
http://community.webshots.com/photo/...69831397rvWYBz
Without the vest I feel the eye needs the belt to break up the long void down the center of the body from the tie to the sporran. The buttons on the vest serve this purpose very well as well as obsuring the straight line where the shirt and kilt meet. You would still have this line with the belt but for some reason the belt and buckle help it look better.
I also found this link on formal scottish wear
http://articles.pointshop.com/music/56019.php
I can't vouch for it's accuracy but I read nothing in it that was blaringly incorrect.
As is your outfit looks fine, but since you wanted to tweek it a bit thiese are just suggestions of my preference. Wear the kilt and have a great time!
8th August 06, 08:21 AM
I got rave reviews for this look (mainly from people on this forum). I know this isn't exactly as formal as you will be, but this pic shows kilt height, sock fold, sporran height, and belt placement. Also, I run the sporran chain or strap through the belt loops on the kilt, and the belt over the belt loops.
Just keep in mind, if there are other kilted people there, they will help you with any last minute details. If not, they won't notice little imperfects in how you are dressed. The kilt itself will steal the show.
In regards to flashes....think of them as a little extra bling. Not a necessity, but really make you look sharp, and bring the whole ensemble together.
