My kilt is too big...
I just ordered my first kilt (for my wedding) direct from Scotland. I got it today and I absolutely love it. However, it does seem a bit big around the waist. I'm wearing it up where it belongs, 2 inches above my actual waist line (I wear it around my naval). However, without the belt being incredibly tight I feel my kilt would need to be pulled up all night long to keep it up around me. I want to have it altered. Where should I take it? What should I ask them to do? The wedding is in 15 days.
we need to know where you are to tell you where to go.
depending on the maker, perhaps suspenders are the key
Connecticut, USA
I live in the States. Connecticut to be precise.
Assuming you have the kilt straps buckled as tight as they go...does the kilt slide over your hips to the floor?
If it doesn't, or if adding a belt holds the kilt up, I would suggest you just practice wearing the kilt and get used to the "feel" of the kilt. It may not be as likely to slide off as you fear. Would recommend taking it out for a hike somewhere remote where if it does slip too far you won't be embarrassed.
You may find the feeling that its gonna slip off is just getting used to wearing the kilt.
Now if that's not the case and its way too big then go with the suspenders under your jacket.
Ron
Rather than suspenders, if it's just a little loose, you only need to have the buckles moved a bit and it should cinch up nicely.
Be well,
If you're going to do suspenders...
Be well,
Don't try to use Aligator-clip type suspenders with a Tank... (they won't hold, and if they do, they'll either be ruined or mar the tartan IMHO) have buttons sewn inside the apron and use proper buttoned suspenders...
Very good advice.
If your time constraints prevent any of the tailored options, a good pair of button braces could help solve the problem quickly.
Had the same problem, if you have the time the straps could be moved if not suspenders are the fast fix. However use button ones not the clip type.
it should be worn higher than the navel though shouldn't it?
3rd July 09, 10:48 AM
All good sound advice indeed. Did you loose weight or order the kilt to large?
In the long term moving the straps might be your best bet if time allows!
