3rd March 05, 10:49 PM
No Iron Trick for Contemporary Kilts
Hope this comes out. What works for me is to hang the kilt from three hangers hanging from a shower rod.
I've made up about four dozen weighted clips from WalMart hanger clips, duct tape, and half ounce lead fishing weights. Tape a weight to each side of each clip.
The clips are attached to the bottom of each pleat seam - front and back - while the kilt drys.
The weight pulls the seams straight while they dry.
No ironing needed. Simple matter to attach the clips and detach the clips.
Ron
3rd March 05, 11:08 PM
If you want to try Ron's trick without having to glue beaucoup weights to clips, I have a possible solution.
I cast bullets for a .45-70 rifle. The bullets weigh 510 grains each, that is a trifle under 1 1/8 ounce. They can be glued to the clip or tied on with string or fishing line, or taped on with duct-tape or elecrical tape. This will allow one bullet per clip, giving a slightly greater weight per clip than using two half ounce fishing weights.
I will be glad to sell unlubed bullets for $00.25 USD each plus shipping.
3rd March 05, 11:24 PM
Great idea Doc,
I started out tieing the weights on but the tie threads kept breaking off when the clips were in a bag between uses. Good ol' duct tape saved the day.
Never thought of bullets.
Ron
4th March 05, 12:06 AM
 Originally Posted by Riverkilt
Great idea Doc,
Ron
Mighty few problems that can't be cured with the proper application of duct tape or a .45 caliber bullet. :P
4th March 05, 10:06 AM
What would we have done without duct tape? Great idea Ron and Doc!
Glen McGuire
4th March 05, 10:46 AM
Hey guys, it works on leather too.
My saffron RKilt came in with a couple expected folds from being in the shipping container.
Hung it out (took 4 hangers) and used the weighted clips on the bottoms of the seams overnight. Worked well to reshape the leather from shipping.
Ron
5th March 05, 12:20 PM
It almost seems like less work to iron it. Ironing isn't that big a deal, IMO.
21st April 05, 10:45 AM
Great idea Doc,
Ron
Amen Doc, you beat me to that one. Sometimes I think that if it wasn't for bailing wire and duct tape the whole dang country would fall apart.
Jerry, Kilted Old Fart.
21st April 05, 11:36 AM
Ron,
Have you tried taking another set of hangers and adding extra clips, like you do for the kilt hanger, but have say 6 or 8 clips that correspond to a pleat then rather than affix the individual weights to the clips afix "the weight" to the hanger.
21st April 05, 01:07 PM
Not sure I understand.
What I do is hang the wet kilt out of the washer up on three hangers to dry, straighten the pleats by hand, then clip a weighted clip to the bottom of each pleat to keep the pleat stretched and straight while the kilt dries.
Haven't had to iron anymore.
Ron
