28th November 08, 11:14 PM
Pleats are goofed
Ugh. Like a fool, I wore my kilt out to the D/FW Kilt night, and the pleats are a bit askance. I have to wear the kilt tomorrow/today (Saturday) for my wedding! What I need to know is if it's safe to just steam the pleats without doing that sewing bit in the tutorials.
I realize there's probably a thread on this, but as I have to be up by 7:30, I need to sleep so I'm hoping someone can drop some advice by the time I wake up.
Thanks!
28th November 08, 11:43 PM
I've always just steamed my kilts, or pressed 'em carefully - never bothered w/ basting.
Congrats, btw!
- The Beertigger
"The only one, since 1969."
29th November 08, 12:07 AM
Yep. I just finnished steaming my wool kilt a little while ago; mostly to try out my new steamer. Hung it from the shower rod with no basting involved. I did the same with the non-wool kilt earlier.
I don't know which kind of kilt you have, and how you normaly hang it. I have a hanger on the aprons and one on the pleats. I just hang it up like that and shoot steam at it from a few inches away from the surface of the pleats, then I put the hanger with the aprons on the other side to do the other pleats.
I smoothe over the pleats with my hands on either side of the kilt pressing them together a little, then I repeat the steaming. If there is still a rumple somewhere, I work at it with steam then smoothing until it's OK.
I've never had a problem with my wool kilt that has required more than a tiny bit of steam or even just hanging in the closet for a day, though.
29th November 08, 06:24 AM
If ironing them make sure you use a cloth betweeen the kilt and iron, so as to avoid the burnt shine on the wool.
29th November 08, 06:52 AM
Life savers, both of you.
Thanks!
29th November 08, 07:18 AM
ALSO... if the pleats are just a little wrinkled, try leaving the kilt hanging on the OUTSIDE of your shower rod or on your towel rack while you take a hot shower. OR... turn the shower on 'scalding' and don't take a shower, but close the door and leave the room for 10 min or so. Let the steam room effect lessen the wrinkles.
29th November 08, 03:38 PM
That's the technique I use when on the road. When the shower is finished, both the kilt and I are ready to go,...well almost.
29th November 08, 04:53 PM
Great advice from one and all - I just wanted to add my best wishes to you both on your wedding day!
29th November 08, 07:29 PM
I won't add advice. . . . you have a lot of good stuff there. Just wanted to say congratulations and best wishes!
Post pics as soon as you can.
By Lily in forum Miscellaneous Forum
Last Post: 23rd September 08, 07:40 AM
By dana in forum General Kilt Talk
Last Post: 10th February 05, 05:12 PM
