Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    9th November 11
    cable Wi.
    re blocking a tam
    My mother found a lovat blue diced tam in a thrift store and gave it to me
    It's old,has a little moth damage and the band is stretched out,but still cool.
    I has been ill used of late and I would like to return to it some of it's former glory.So got any advice on re blocking or pressing an old tam?The lable says 100% pure new wool made in Scotland.
    Thanks
    Andy
    KILTED LABOWSKI
    "I imagine a place of brotherhood and peace, a world without war. Then I imagine attacking that place because they would never expect it.
    19th May 08
    Oceanside CA
    If it's knit, here is a short description of blocking a tam. The same site has other blocking instructions for various knit items.
    9th November 11
    cable Wi.
    Pics,
    Thanks Sydnie,
    The diceing is knit how can I tell if the body is?If the band is the body should be right?
    Andy
    KILTED LABOWSKI
    9th October 10
    Outskirts of Chicago IL
    26 Post(s)
    1 Thread(s)
    http://www.xmarksthescot.com/forum/f...almoral-57667/
    I am not certain, but perhaps this can be of help
    Does not look knitted to me. The diced band is knitted, but does not look felted, whereas the hat itself is felted, so I do not think it is knitted.
    Harold Cannon's Avatar
    Harold Cannon is offline Oops, it seems this member needs to update their email address
    15th April 08
    Alabama
    I think it has some character about it. As far as the band being stretched out you could have grosgrain ribbon attached to the bottom like a balmoral usually would. Then you could have an adjustable ribbon to take up the slack. A new cockade would be nice as well, maybe something in livery colors. As far as blocking and pressing I wouldnt. I would just wet it then put it on and shape it to my liking, then wear it until dry. Just my opinion though.
    If you have questions about attaching the ribbon just look at my thread on how to make a DIY balmoral.
    26th March 08
    Atlanta, GA
    Aye, as someone with more experience here than I'd like to admit to, stretching your wet hat around a dinner plate is a really fast way to end up with sub-par results.
    I'm familiar with that style of hat, and honestly, that particular one just looks like it is a bit tired.
    9th November 11
    cable Wi.
    Ryan,
    I'm thinking your right,the more I look at it the more I feel it has made the proverbial farm purchase.It's sad but true I think.
    Andy
    KILTED LABOWSKI
    If you want to stretch out the top part, dip the tam into warm water and squeeze it out, then put a length of fairly heavy power cable into it, with the ends held together with a cable tie - one of the adjustable sort if you can find one. Make the ring of cable as large as possible without it bending out of the horizontal, and make the join as smooth as possible. Leave to dry almost but not quite completely, then brush up the nap to disguise the moth damage as much as possible, put it on and adjust to the final shape, wear until dry.
    The moth holes can be repaired by grafting - recreating the stitches either with well matched yarn, or a transparent or dull coloured sewing thread.
    The band looks to have been made from a strip sewn together, so it could be undone and something slid into the fold to stretch the band in the direction of knitting during the wet phase of the reshaping, which will pull it narrower, as is the way with knitting. If it isn't possible to open the seam, when the tam is wet take hold of the edges, where it is joined to the top and the outer edge, and gently pull. Go around the brim inch by inch several times until it is drawn out.
    Anne the Pleater :ootd:
    15th April 08
    Alabama
    Well cable scot and I worked out a trade. I will let him post pictures of what he got but I am happy with lovat blue diced bonnet. I had more moth damage than I thought but nothing that I cant fix. I am about half way through with the refurb work and will post pictures when it is done. I am going for something similar to what the Duke of Argyll wears. It will have a red tourie and a black bottom band.
    I am also looking about a tartan cockade or maybe just a black one??????
