Results 1 to 5 of 5
    18th July 12
    semi traditional kilt
    what exactly is a semi-traditional kilt? how does it differ from a casual kilt?
    14th May 12
    Maine ... The Way Life Should Be!
    Check out the descriptions on the USA Kilts website (link at the top left of thia page). Essentially their "casual" models are PV kilts with velcro closures. The "semi-traditional" kilts are also PV but made more like traditional kilts with leather strap and buckle closures, etc.
    Either way Rocky and crew offer great products and superb customer service.
    Mike Nugent
    Riamh Nar Dhruid O Spairn Lann
    8th February 04
    1 Thread(s)
    Based on your use of the term "Semi Traditional", the fact you PM'd me with a question and based on your previous threads asking about USA Kilts, I assume you're referring to our poducts. If that's true, then:
    2 links to check out:
    http://www.usakilts.com/index.php/in...ht-for-me.html
    http://www.usakilts.com/index.php/in...-a-kilt-1.html
    You can also add both to our "compare" feature (right by the "add to cart" button) and compare them that way. Also, check out the "Specs" tab under the product pictures -
    Our Casual Kilts are made with the following specs:
    - 11 to 12 oz. Poly Viscose material woven in the UK
    - Material is Teflon (TM) coated and has 'Lo Pill Fiber (R)' technology
    - 4 to 5.5 yards of cloth are used
    - Pleat width is 1.5"
    - Roughly 15 to 20 pleats
    - Selvedge edge is a tuck selvedge OR are hemmed if the selvedge is fringed.
    - 3 belt loops (5 on men over with waist over 48")
    - Velcro closure
    - Top Stitched
    Our Semi Traditional kilts are made to the following specs:
    - Material is Teflon (TM) coated and has Lo Pill Fiber (R) technology
    - 5.5 to 7 yards of cloth are used
    - Pleat width is .9" to 1"
    - Roughly 18 to 28 pleats per kilt
    - Selvedge edge is a tuck selvedge OR is hemmed if the selvedge is fringed
    - 2 belt loops on the back to accommodate a 2.25" kilt belt
    - Traditional 3 buckle closure system
    - Fringed front apron
    - Top stitched
    24th November 05
    Clodine, Texas
    I don't have a casual to compare it to, but here's my review of a USA Kilts Semi-trad;
    http://www.xmarksthescot.com/forum/f...-review-60943/
    8th August 07
    Westchester/Putnam NY
    I hand sew semi-traditional kilts using 5-6 yards of woolen tartan. Compared to an 8 yard kilt, there are fewer pleats and they are a bit wider. The sewing time is a little less because of fewer pleats, but otherwise I sew it the same as for a traditional 8 yard knife pleated kilt. I do pleat cut-outs, steeking, waist stabilizer, canvas, lining, belt loops, buckles and straps.
    If it's a 4 yard casual kilt, there would be even fewer pleats and the pleat width would be wider. I wouldn't do cut-outs and would probably not do a buttonhole for the underapron strap. Instead, I'd do an inner buckle as done on 4 yard box pleated kilts. If wanted, I could do a velcro closing.
