Results 1 to 10 of 12
jjoseph sewn in weights (clipped from... 20th May 06, 09:43 AM
Jewddha I'm no tailor, but I can... 20th May 06, 10:46 AM
Pleater Try sewing in a tape or... 20th May 06, 12:18 PM
Iolaus Attach small tabs of velcro... 20th May 06, 12:21 PM
Aggie I have read that Duncan on... 22nd May 06, 07:24 AM
switchblade5984 i had often thought about... 22nd May 06, 10:26 AM
Riverkilt Seems like they'd cause... 25th May 06, 05:40 PM
Pleater The weighting strip for net... 25th May 06, 05:55 PM
    1st June 05
    Pittsburgh, PA
    Question sewn in weights (clipped from '4yd vs 8yd' thread)
    Quote Originally Posted by bubba
    I do know that a 4 yard gets blown about in the wind a lot. The sporran keeps the front down but not the back. Still, I guess what you cannot see you don't worry aboot!
    There's a trick that I learned about from one of the ladies on a sewing newsgroup. Stitch a few fishing weights around the hem. The ladies have been using this trick to keep light skirts from flying up in the wind for a very long time
    I had thought about doing something just like this, BUT I wasn't sure if it would cause the garment to wear out... I know that pulling on fabric or frames does not have to be heavy or hard; if it's done over a long time it will pull them apart.
    So my questions for you tailors, kiltmakers, seamsters and seamstresses are, "What do you think of sewing in a few weights? Will it unbalance the garment or cause excessive wear? Would the kilt need to be stored flat rather than hung?"
    29th December 04
    Victoria, BC
    I'm no tailor, but I can think of a few options.
    Firstly, make them removeable. Depending on the style of kilt this would be easier or harder. Frankly, if you wanted to do it, this seems the only "safe" way, because if you do this on a contemporary kilt that get's put in the washing machine, I think it might just tear it apart.
    Secondly, maybe add a band of some sort of light reinforcement along the line where the weight would hang.
    Try sewing in a tape or ribbon along the hemline - that will actually reinforce it rather than do damage. You might need to sew the folds into the tape to keep the kilt's pleats sharp
    If you need more weight than that you could try adding net curtain weighting strip, which is a continuous tape either with small beads in - which is not the best option, or a smooth strip of plastic-y stuff which can easily be cut into short lengths. You could then put a strip of it along the hemline of the underside of the pleat, or vertically into the lower part of the inner pleat and then sew the fold down to make a narrow pocket from which the tape could be removed for washing.
    I am assuming that type of weighted tape is available to you, though if you use the pocket method you could use any small weight, but wrap it to prevent damaging the fabric. A strip of old handkerchief of a thin shirt material would do the job.
    13th March 05
    Orange County, CA., U.S.A.
    Attach small tabs of velcro to where you want the weights, and glue the opposing peice of velcro to some nickles?
    I think adding weights to the edge might substantially change the way the pleats "swish." The only place I can think of that a weight might help, would be the corner of the outer apron; sew a little pocket about an inch in, and drop a coin into it.
    8th November 05
    Bryan/College Station, Republic of Texas, USA
    I have read that Duncan on MOTG had weights sewn into his kilts.
    8th November 05
    Fresno, CA
    i had often thought about that.....
    thanks for the ideas all
    16th November 05
    santa clara CA
    I don't know if it will wear out the kilt,but, it may wear you out. It would also make a great weapon
    Seems like they'd cause bruises bumping against knees and legs.
    Solution for me has been to hike in the wind and get used to the kilt blowing around, its usually not as bad as we think because we're not as used to it as women are.
    And, gee, was just a few weeks ago I had on my heavy leather UK and the wind still blew that up. Would guess its even heavier than a lighter weight kilt with weights.
    Visions of weighted hems flying up in the wind and giving bystanders uppercut blows to the chin.
    Ron
    The weighting strip for net curtains is not nearly heavy enough to cause bruising - now the stuff for curtains is the sort of thing that could be used for a martial art - particularly if sharpened at one end and secured at the other so it could emerge from the pleats like feline claws....
