Results 1 to 10 of 18
    7th January 08
    Sugarland, Texas
    thoughts on these two makers
    I am considering a kilt from
    Houston kiltmakers
    Geoffrey Tailor
    Twentyfirst Century Kilts
    any experience? any differences between the three?
    11th March 08
    New Jersey
    Geoffrey (Tailor) and 21st Century kilts are the same. Though the latter is their more "contemporary" line, as the name would indicate.
    So, really, you've given two choices, and both are very reputable, indeed. You wouldn't go wrong either way.
    "To the make of a piper go seven years of his own learning, and seven generations before. At the end of his seven years one born to it will stand at the start of knowledge, and leaning a fond ear to the drone he may have parley with old folks of old affairs." - Neil Munro
    JakobT is offline Oops, it seems this member needs to update their email address
    15th January 08
    I own a kilt and a kilt suit from 21st Century Kilts, with a third kilt on order. I'm very happy with both the quality of the products and the service, and can wholeheartedly recommend them. As JerseyLawyer says, 21st Century Kilts and Geoffrey (Tailor) are one and the same, so expect the same high standard.
    7th January 08
    Sugarland, Texas
    jerseylawyer, have a pic of the kiltsuit?
    have you worn it to court?
    seems houston is a little higher regarding a full weight kilt any thing that sets them apart?
    11th March 08
    New Jersey
    The kilt suits in question:
    No, I don't wear a kilt to court, but that's because, well, I work for the government, and it would be frowned on, I suspect.
    As for Houston Kiltmakers, I don't know. They're a very traditional maker, and I've only heard good things, but I don't own one of their kilts. I would say the difference of an ounce won't make much in the finished product.
    7th January 08
    Sugarland, Texas
    have a pic of you in it, i would like to see it on a real person instead of their models
    11th March 08
    New Jersey
    Quote Originally Posted by copey713 View Post
    No, sorry, not my style. Though I think there is a picture of Hamish in one on here somewhere... Let me see if I can find it.
    11th March 08
    New Jersey
    As always Hamish looks very well turned out,but that style is not for me.
    29th March 07
    Edinburgh
    I got a full PC rig from Geoffrey tailor a number of years ago, The kilt is ancient dress gordon which was woven to order. I was pleased with the PC jacket and accessories although i found the gillie brogues a bit narrow.
    I have not been overly pleased with the mactufacture of the kilt. I did put on a bit weight and found the material stretched badly. This was compounded by the fact the leather waist strap was only sewn through the tartan and not the lining, which would have made it stronger. In addition the stitching in the pleats at the back has teased meaning it is visible (slightly) and wolud be a lot worse in the tartan were darker (the stitching is white).
    While some of you might not be sympathetic to the circumstances of the kilt being stretched I also have a Hector Russel kilt which was made for me in 1989. This is a narrower kilt (l was a lot slimmer then) however I wore this a lot when I was bigger too. The build is much more robust and there was no teasing of the stitching. Although the material did stretch a little, nowhere near to the same extent the straps were also a lot more secure.
    I would not in the circumstances reccomend a kilt from Geoffrey tailor. i will be looking for a new kilt shortly and will look at Hector Russell as well as some others.
  1. Sporran makers
    By scratchy in forum How to Accessorize your Kilt
    Last Post: 17th September 07, 02:46 PM
  2. X-Kilt Makers
    Last Post: 3rd May 07, 01:26 PM
  3. Thoughts on Erskine's thoughts . . .
    By andyfg in forum General Kilt Talk
    Last Post: 15th May 06, 05:00 AM
  4. Sporran Makers
    By Miah in forum How to Accessorize your Kilt
    Last Post: 10th May 06, 04:07 PM
  5. For All Kilt Makers
    By RockyR in forum Professional Kiltmakers Hints and Tips
    Last Post: 20th October 04, 02:18 PM
