Results 1 to 10 of 11
    20th May 17
    NJ
    Top band, buckle tab and sporran loop question
    Why when such care is taken to match twill lines, pleats, and dimension are top band, buckle tab and sporran loops not matched? Just curious, I kinda like that they aren’t as it adds a bit of playfulness.
    7th February 11
    London, Canada
    It all depends on how careful the kiltmaker is. On my kilts, they all match.
  3. The Following 2 Users say 'Aye' to Father Bill For This Useful Post:
    Kerrville, Texas
    8 Post(s)
    They match on my kilts too.
  5. The Following 2 Users say 'Aye' to Tobus For This Useful Post:
  6. #4
    20th May 17
    NJ
    Thanks for the reply boys
  7. The Following User Says 'Aye' to Me cousin Jack For This Useful Post:
  8. #5
    7th February 11
    London, Canada
    Now... If you have to move the buckles/ straps because of weight gain or loss, they may no longer match very well.
  9. The Following 2 Users say 'Aye' to Father Bill For This Useful Post:
  10. #6
    Quote Originally Posted by Me cousin Jack View Post
    The tartan on the top band and buckle tabs do match--------nearly, on my two bespoke(and only) kilts and neither have belt/sporran loops.
  11. The Following 2 Users say 'Aye' to Jock Scot For This Useful Post:
  12. #7
    8th October 12
    Cornwall, Ontario
    There is no reason why the buckle tabs and keepers do not match, save for lack of care and attention. As for the top band, I would say it should probably match on the front apron, but may get slightly off as you travel across the pleats. My good kilt is pleated to the strip, and so, my waistband does not match the stripes all across the back.
  13. The Following 2 Users say 'Aye' to plaid preacher For This Useful Post:
  14. #8
    29th April 07
    Columbia, SC USA
    I second the observations of Jock Scot and plaid preacher.
    If the top band is tartan, it should match the apron. Since the pleats are tapered at the waist (usually), it will not match the back and underapron. If waist and hip sizes are the same, it might nearly match all the way 'round. That's an unusual measurement, but not unheard of. However if the kiltmaker allowed a slight flare in the rise (the bit above the waist), then it will diverge. That's done to keep the kilt's waist at the wearer's waist.
    The buckle tabs are typically made from the leftover bits of the tartan, and matched to the pattern beneath. Usually they are short enough to be covered by the strap when the kilt is worn, so it's not critical---just esthetically pleasing. I had to make new one for a kilt I've been wearing 12 years, and made a temporary one from a non-matching broadcloth scrap. This works, but I'll replace it with a color that's in the tartan. I did not make this kilt, so it's unlikely that I'll find a matching tartan scrap; but again, that won't bother me since it's not seen.
    Pardon the pedantry, but I'm at Kilt Kamp and those details surround me!
  15. The Following 2 Users say 'Aye' to fluter For This Useful Post:
  16. #9
    4th June 19
    Guelph, Ontario
    On my semi-trad the buckle tabs don't match but the straps cover them when buckled. The overall quality of the kilt is excellent so I just turn a blind eye.
  17. The Following User Says 'Aye' to TAB For This Useful Post:
  18. #10
    20th May 17
    NJ
    Thanks all for your help, I see now why they don’t match but only around back at the pleats.
