4th November 04, 09:12 AM
Want help with material weight
Could you explain the weight of fabric? Is that ounces per liner yard? If so, how do you compare when some fabric comes in wider rolls then others.
Also how can I find out the weight if it is not marked on the roll without actually weighing it. I see a lot of the rolls do not tell the weight, or I at least can't find it. Is it coded some way?
Finally.. what weights are good for the various kilts, such as the Amerikilt Cotton, Wool and PV light weight for summer and heavier weights for winter?
What weights does Bear and USA Kilts use and why?
Thank you!
Please be as detaild as need be.
Thank you!
Thank you!
4th November 04, 09:47 AM
You get the weight of wool (by taking a yard of the material "doublewide" (approx 56" to 60") and weighing it. That gives you the material weight. I'm not sure how else you can get the weight without weighing it... aside from just feeling it and giving a guess.
We (USAKilts) use different weights and types of material. Our most popular material is our PV (Poly Viscose). I do not know the actual weight of the material, but I'd be willing to give an educated guess at about 11 OZ.
I hope this helps.
I hope this helps.
I hope this helps.
4th November 04, 11:35 AM
The specified weight of any fabric, is the weight of one linear yard (or meter, depending on where it was woven) as it comes off the bolt, regardless of width.
Material from a bolt of 24" goods, that is said to be 8oz. will be the same thickness as material from a 48" bolt of goods rated at 16oz.
Without the experience to be able to tell from the feel of the cloth, weighing a yard of the material is the only way I can think of.
When bying yardage in person, if the specific weight of the fabric is not on the bolt of goods, I go by the feel of the cloth. Thick/heavier for colder weather, thin/lighter for warmer weather.
4th November 04, 11:48 AM
Yep Ant has the same understanding I do yard of the cloth square yard as i understand it.
