Results 1 to 5 of 5
Thread: 1/2" strap?
Iolaus 1/2" strap? 26th April 06, 09:23 AM
bangkok kilt half inch seems a bit narrow,... 26th April 06, 09:30 AM
switchblade5984 those are called french snaps... 26th April 06, 09:34 AM
cavscout Mine are 1/2" to 5/8" wide... 26th April 06, 09:47 AM
Tartan Hiker The entire strap doesn't have... 26th April 06, 09:51 AM
    13th March 05
    Orange County, CA., U.S.A.
    1/2" strap?
    I found some rather unique looking brass clasps, but they would only fit a narrow strap, and the clip and attached links are already just over 3" long, so I don't want to add more hardware. Is a 1/2" strap too narrow to use as a sporran strap?
    22nd April 06
    half inch seems a bit narrow, but I think it would look just fine. plus those clasps are great. they would go great with a brass belt buckle.
    8th November 05
    Fresno, CA
    used alot in falconry and very strong.... for a while they wear out quickly
    27th January 05
    Jefferson, Georgia, USA
    Mine are 1/2" to 5/8" wide and work and look fine...I think
    29th January 06
    Asheville, NC
    The entire strap doesn't have to be 1/2", just narrow down the ends of a wider strap to fit the eye of the snaps. It'll be strong enough, if that's the concern. Lots of western style belts use a buckle that is much narrower than the belt with no problems.
    You could even attach the snap by using a separate piece of 1/2" leather stitched onto the wide strap.
