Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
    29th January 06
    Asheville, NC
    Clan badge as kilt pin?
    I have a clan badge but no hat to put it on. Is it OK to use it as a kilt pin or is this a breech of kiltiquette?
    23rd January 04
    Raleigh, NC, USA
    Quote Originally Posted by Tartan Hiker
    Nothing wrong with that. I have seen that before. I think it looks fine.
    -ian
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    kilt pin...
    Technically there is no "rules" prohibiting it, but I tend to think the chief's crest badge for a bonnet is too big for a kilt pin. That's just my opinion, though.
    Todd
    Graham's Avatar
    Graham is offline Oops, it seems this member needs to update their email address
    4th February 04
    Tasmania, Australia
    My concern would be stagging it on something and ripping the kilt.
    21st April 05
    Tartan Hiker,
    Do you need a kilt pin or is it just the hat you don't have for a clan badge? I have an extra kilt pin that I don't use.
    Something to think about: Isn't there usually a discernible weight difference (between clan badges and kilt pins) that would by necessity negate following through with this idea? Although I think it might look alright, I'm with Graham and would be worried about the badge tearing the kilt; my concern stems from the badge being too heavy as it might over time cause quite a hole or tear just from having it pinned to the kilt apron.
    8th February 05
    Chester County, PA
    I have an antique hallmarked silver Mackay Clan badge that I use as a kilt pin and have never had any issues with the weight or any wear on the kilt fabric. It is no heavier than any other kilt pin I have used.
    I actually bought the badge specifically to wear as a kilt pin as I do not generally wear a bonnet and did want to show my affiliation to the Chief of my Clan, Lord Reay.
    Brian Mackay
    "I find that a great part of the information I have was acquired by looking up something and finding something else on the way."
    - Franklin P. Adams
    21st April 05
    Good point about the antique silver, Brian; maybe I should have been more specific and stated using a pewter clan badge may not be a good idea, whereas it seems most badges are made from this heavier alloy these days.
    29th January 06
    Asheville, NC
    Thanks all. I've never even held a "real" kilt pin, so I have no idea of the relative weight of the two. I have a typical pewter badge (that I got on eBay from a fellow in New Zeland). It doesn't seem heavy enough to cause a sag, and I don't use it while hiking or any time that it may snag on something.
    I suppose the orientation of the pin itself (vertical as opposed to horizontal) plays a role as well.
    Bill
    21st April 05
    Thanks all. I've never even held a "real" kilt pin, so I have no idea of the relative weight of the two. I have a typical pewter badge (that I got on eBay from a fellow in New Zealand). It doesn't seem heavy enough to cause a sag, and I don't use it while hiking or any time that it may snag on something.
    Bill
    Bill,
    PM me your address and I can send the extra kilt pin to you if you want it. Here's what it looks like (it's actually about half the size of this photo):
    Forum Historian
    22nd June 04
    kilt pin...
    Another option for a kilt pin is the large "safety pin". You can usually find these at fabric stores for around $3-5 dollars.
    http://www.doyle.com.au/images/kilt_pin.jpg
    These kilt pins are based on the ones worn by the Highland regiments. I like them for their simple design.
    Todd
