Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    15th October 09
    Dallas area
    Question A different sytle of sgain dubh?
    Hey all,
    I'm working on a sgain dubh and it's seems to be going ok but the hidden style tangs have never been my style. Most of what I do is full tang.
    Would you guys buy a sgain dubh with a full tang or would you pass it by?
    Thanks for your time,
    Jim
    It depends, I might for day wear.
    23rd June 09
    Southeastern Michigan
    I agree with Jock. I generally favor full tang in a knife, but I can't imagine one that would have the right look for a formal occasion. Perhaps I just haven't imagined the right one.
    23rd August 06
    Salt Lake City, Utah, United States of America
    If I could afford it I would. It would be my only Sgian Dubh. I am short on funds
    23rd August 06
    I did come across a custom Sgian Dubh with a full tang somewhere. I have the images somewhere to use as a pattern.
    19th October 09
    South Carolina
    If weight is a consideration, don't you add poundage with a full tang? Can you oxidize the edges of the tang to keep it dhu? Could you skeletonize the tang and still consider it "full"? Compare the skeletonized buttplates on some shotguns or drilled out ultra light bicycle components... The difference would be that all of that missing metal would be sandwiched between your scales, which might then have to have a different means of attachment. Your pictures will eliminate my next thousands of words...
    Cordially
    MacLL
    22nd September 08
    Aberdeen/Huntly, Scotland
    Sorry but whats a full tang?
    He kens na where the wind comes frae,
    But he kens fine where its goin'.
    23rd August 09
    Lille, Nord, France
    I would love to own the sgian dubh equivalent of a Laguiole pocket knife such as this:
    Those not familiar with the company (and unable to visit beautiful Laguiole itself, in southern France) should check out http://www.laguiole-en-aubrac.com/. They also do some cutlery:
    Nothing quite like a sgian dubh there, but I have no trouble imagining such, with a full tang and a properly formal look.
    Garrett
    "Then help me for to kilt my clais..." Schir David Lindsay, Ane Satyre of the Thrie Estaitis
    15th October 09
    Dallas area
    This is a hidden tang blade also call stick, snubb, through or mortise tang depending on how its used in a handle. The tang doesn't show once the blade is complete.
    This is a full tang. It will show on the sides once the handle is complete.
    I'm familiar with the company. It's trademark is the clicking sound the blade makes as it opens. They always look beautiful. The fix blades cutlery is intergeral. meaning the bolsters (the metal between the blade and wood) is part of the blade instead of added on like I do. Without a mill I won't want to try that but the filework on the folders is something I could and would do on the tang of the blade to make it more dressy.
    Wjile a full tang is heavier than a stick tang in a small knife like this it wouldn't add much weight. I also taper my tangs for ascetic and weight issues. Since I flat grind I always get a distal taper. A tapered tang balances to looks as well as the weight.
    Here's one of mine that has a tapered tang to get the idea -
    Thanks for the opinions.
    Keep them coming,
    Jim
    17th March 10
    Mission, BC Canada
    Quote Originally Posted by Drac View Post
    Keep them coming,
    Jim
    Jim, that is a beautiful piece of workmanship - one anybody would (should?) be proud to wear and use! Do you make your own sheaths too?
    Steve
  1. My first sgain dubh
    By SingleBarrelBourbon in forum DIY Showroom
    Last Post: 5th January 09, 03:41 PM
  2. sgain dubh blades
    By DWFII in forum DIY Showroom
    Last Post: 3rd September 08, 07:40 AM
  3. second sgain dubh--a commission
    Last Post: 30th August 08, 03:09 PM
  4. sgain dubh ???
    By Robertson in forum How to Accessorize your Kilt
    Last Post: 10th January 08, 04:13 PM
  5. show off your sgain dubh III
    By Joe Gondek in forum How to Accessorize your Kilt
    Last Post: 20th June 06, 09:26 PM
