Results 1 to 10 of 13
    toadinakilt
    Hose Topper Thingy's
    Can somebody explain the purpose of hose toppers or whatever they're called? I've seen some really nice looking ones, but I'm having a hard time figuring out what role they play in an outfit...
    19th May 08
    Oceanside CA
    Basically, they are an alternative to more expensive hose that have a permanently attached decorative cuff. You can also swap them between hose of varying colors, and replace the hose when toes/heels wear out but keep using the cuffs with new hose. Not the same look as custom-matched, hand-knit hose but an alternative for everyday wear.
    25th November 09
    Lomita, CA (via Boston, MA)
    She Is Being Modest
    I have 4 pairs of Sydnie's Hose Toppers and they are fantastic. I have gotten compliments nearly everytime I wear them. She is correct about being able to swap them with different hose. I have one pair that go ideally with both a solid forest green or a lovat green. I would personally recommend them.
    30th June 06
    Lotusland, Canada
    See the attached site for the story.
    http://www.bigmikeyoriginals.com/
    Gentleman of Substance
    2nd October 07
    I have one pair of Sydnie's and two of Big Mikey's. They really spruce up an outfit.
    16th January 09
    outside Rochester, NY
    I also have 2 sets of Big Mikey's and am very happy with them.
    14th January 08
    San Antonio, TX
    I won a pair of Big Mikey's several months ago in a contest he was running. He custom made them of yarn color and pattern matched to my Ancient Caledonia Kingussie (Keltoi)kilt and they look great with about 4 or 5 different color solid hose I can wear underneath them. Normally I would wear a multicolor fancy hose with most kilts if at all dressy, either argyll tops, pattern tops, diced or full argylls, and this is a much less expensive option that allows for multiple top and hose body combinations to be worn with any given matching kilt. My review:
    http://www.xmarksthescot.com/forum/f...-reward-58356/
    They can even make a white pair of hose (normally taboo to most) look very good as they add that additional splash and pattern of color to the stark white of the hose body.
    jeff
    2nd April 10
    Stamford, CT
    What keeps the toppers in position? I have seen one pic on line of one falling down, but I assume they do not always do that since people keep wearing them.
    19th May 08
    Oceanside CA
    Quote Originally Posted by AFS1970 View Post
    On most people, the tension of the knit cuff itself is enough to keep it in place (unless you are sword-fighting or -dancing, I suppose!). "Spindleshanks" might need either a smaller than usual size, or a round of light elastic built into the cuff. I have also made larger than usual cuffs with elastic inside to allay any fear of sagging.
    Once the cuffs have been worn and stretched a bit, they can be restored to original size by gently pulling top and bottom, all the way around the circumference. I include instructions on this, as well as washing info, with every pair sent.
    toadinakilt
    So... If I had one kilt (for the sake of argument, let's say in Douglas Modern), I could purchase a black or gray pairs of hose, and get different hose toppers to compliment my shirts?
  1. Thanks Big Mikey! Hose topper reward
    By ForresterModern in forum General Kilt Talk
    Last Post: 1st April 10, 01:23 PM
  2. REVIEW: Tartan hose cuffs = £30! Henderson Highland Hose
    By Paul in forum How to Accessorize your Kilt
    Last Post: 10th October 09, 03:58 AM
  3. Kilted Wedding Cake Topper (picture)
    By Ayin McFye in forum How to Accessorize your Kilt
    Last Post: 13th June 09, 06:48 PM
  4. Tartan Hose or Solid Color Hose?
    By dtandthekilt in forum General Kilt Talk
    Last Post: 16th February 09, 10:49 AM
  5. Summer Hose Look, SportKilt $6 Kilt Hose Pushed Down
    Last Post: 20th June 06, 06:33 PM
