Results 1 to 8 of 8
    20th January 10
    AZ
    Kilt Belt Question
    I am in the market for a new leather kilt belt. My question is about the adjustable belts for sale. I have heard that the velcro ones are of less quality, compared to the ones with the small buckle on the inside for size adjustment. I have also heard that some dislike the ones with the buckle because over time the inner metal buckle can wear a spot in the tartan kilt. Can anyone help steer me in the right direction? Thanks.
    "When I wear my Kilt, God looks down with pride and the Devil looks up with envy." --Unknown
    Proud Chief of Clan Bacon. You know you want some!
    1st December 06
    Conyers, Georgia
    19 Post(s)
    I have used both, and I prefer the velcro type the best; I like that way it adjusts and lays flat. But then, I prefer the belts made by CavScout to any of the ones you'll find at most vendors. I like the regular buckle with two thorn roller buckle best, and you'll find that the leather and work surpasses what you'll find in most other belts.
    Check them out here: http://oconeeleatherworks.com/Belts.htm
    Jim Killman
    7th July 09
    Melbourne,Victoria Australia
    I totally agree with The Scot on both the velcro belts and Oconee belts. If you are after a belt then go with Oconee. I have just received one of their brown leather ones with the brass buckle and, as the man said, their quality of work cannot be beat
    30th June 06
    Lotusland, Canada
    I have tried the buckle type belt and found that I didn't like the small bulge that was evident on the side that the buckle was located. After some time wearing it, the buckle became rather uncomfortable. It has now found a new home.
    The velcro belts are good quality. I have one that I purchased from Stillwater Kilts about 4 years ago and it still looks and works like the day I received it.
    Now as to Oconee Leather, if you try the search function, you will find many reviews all singing the praises of Steve's quality products. I own three custom made belts by him and can attest to the level of workmanship. The Oconee belts are not as inexpensive as some but they are definitely affordable, definitely higher quality and with a little care, could be handed down to your grandson along with your kilt.
    Gentleman of Substance
    8th August 09
    Easton, PA
    I have a belt that I bought from the Scottish Lion that was called a gentleman's kilt belt. It has the buckle on the inside but it is also red on the inside. I wore it to work a couple of times and I didn't realize that the red was wearing off on my utilikilt and some of my polo shirts. I never got that red out and I have been too afraid to wear the belt since. What is the point of painting the inside of the belt red?
    17th December 07
    Staunton, Va
    As Gilbert & Sullivan wisely noted...
    Quote Originally Posted by Red Stag View Post
    What's the point? ...as recently as twenty, maybe twenty-five years ago at the most, dirk belts (aka kilt belts, but since kilts don't require a belt to hold them up they are still called dirk belts by traditionalists, fuddy-duddies, and old timers) were finished on the inside with Morocco leather (or sometimes pigskin) dyed red or green. This was done by the manufacturer for a simple reason: pride. In the same way that quality shoes are lined with leather, less expensive shoes are lined with canvas, and cheap shoes have no lining at all, so it is with belts. So, by taking a few extra minutes and providing a lining, the belt maker was showing the buyer that his was a quality belt, not some cheap knock-off from the sweat shops of Rangoon, or wherever it is that most dirk belts come from nowadays.
    Since, in my entire life, I have never had a problem with the red lining of my belt rubbing off on my kilt, I have to suggest that your problem may have been caused by several factors not envisioned by the manufacturer:
    1) If you are engaged in strenuous labour (or sweat a lot) the transfer of moisture through your non-traditional kilt to the belt could have caused dye-transfer to occur;
    2) Since most kilts are wool (a hard wearing but soft fabric) and many non-traditional kilts are made of a rougher, canvass-like fabric, the dye-transfer you experienced could have been the result of abrasion leaving tiny particles of red leather caught in the fabric of your non-traditional kilt;
    or, the vendor sold you a cheaply-made belt with a red lining and there just isn't much you can do about it-- "mutton dressed as lamb" to quote G&S .
    All, however, may not be lost. Here are two fixes you can do in the privacy of your home.
    1) Get some leather cleaner and, following the instructions on the bottle with the same attentiveness you would exhibit if dosing your wealthy maiden aunt Agatha with a potentially lethal medication, clean the red side of the belt, and then using a large supply of clean, soft, dry cloths, polish the red side of the belt until no more red dye comes off on the cloth.
    2) If this sounds too much like work PM me with the size of the belt and, provided it will fit, I'll give you $5 for it. You will, of course, pay the postage.
    1st December 06
    Conyers, Georgia
    19 Post(s)
    Mac of Rath, you is a caution.
    Jim Killman
    5th November 08
    Marion, NC
    Maybe someone was out painting the town red and spilled a little on the belt?
    In response to the OP, I have both kinds of belts and prefer the Velcro one.
    --dbh
  1. Belt Question
    By Robertson in forum How to Accessorize your Kilt
    Last Post: 28th April 08, 07:22 AM
  2. Kilt belt question
    By smaughazard in forum How to Accessorize your Kilt
    Last Post: 26th May 06, 06:39 PM
  3. Another Belt Question
    By Irish in Tacoma in forum How to Accessorize your Kilt
    Last Post: 4th March 06, 09:52 PM
  4. Belt Question
    Last Post: 27th February 06, 10:56 AM
  5. kilt belt question
    By awoodfellow in forum Kilt Advice
    Last Post: 29th September 04, 10:24 AM
