Results 1 to 10 of 14
    4th September 10
    Dallas, Texas
    Kilt Pin attached to the Kilt
    Gents - I'm new to kilt wearing. I just received, over the weekend, my beautiful MacKay Ancient kilt I order while on vacation in Scotland in August from a Haymarket kilt maker. I have most of the accessories I need including two very nice kilt pins.
    Here is my dumb question. Is the kilt pin to be pinned through the outer fold of the kilt as well as the inter fold? I’m not sure if the kilt pin acts more functionally by securing the outer fold to the inter fold or if it more ornamental in nature where it only needs to be attached to the outer fold.
    1st December 06
    Conyers, Georgia
    19 Post(s)
    NO. Outer apron only. Of course, the idea originally was to keep the apron down in the interest of modesty, but the great chance of tearing the cloth means that you only want to pin it through the outer apron of your kilt.
    Jim Killman
    4th September 10
    Dallas, Texas
    thanks Jim!
    15th September 08
    But you know what on a windy day at the highland games I usually pin my appron down to the kilt.
    I am Matty Ross of the Clan ROSS
    26th September 10
    Fort Collins, Colorado U.S.A.
    I usually push it right into my thigh! That way I know it won't go anywhere. Modern wear is through the front apron as has been mentioned.
    23rd September 09
    Vassalboro, Maine
    Wow,I always assumed you would pin it thru to hold it down.
    Jim, good point for that answer.
    I was told by my kilt making teachers not to put in a second buckle unless they were dancers (where you have to admit, they make the kilt swing alot more than most guys walking around to and fro....even in wind)
    chewse, I bet your "Dumb Question" is going to be a hot topic.
    16th May 10
    Capital District, NY
    Although I "only" have a tank, I have found that the weight of the fabric and a "heavy" kilt pin is all I need to keep from catching "too much breeze".
    A suggestion - look at others who have worn your particular tartan and see where they have placed the pin.
    14th March 09
    id say a kilt pin is more decoration rather than a practical item a good weighted tartan shouldn't need to be held down ,a kiltpin is one decoration id never be without when kilted mind you
    22nd November 07
    US
    Last year, I moved my blanket pin to about a third of the way up the apron from the lower corner as someone suggested. I didn't wear the kilt too many times after that, but the placement didn't bother me. It was said that the pin could be pinned through both aprons at that point, if very windy, without causing too much trouble with the kilt, as might happen if they were pinned together at the bottom corner.
    Also, it was said the pin in the corner would tend to cause the top apron to billow out like a sail in some situations, where as, the higher placement would not. I never had a situation to observe if that was the case, but I can understand how that might be so.
    BEEDEE's Avatar
    BEEDEE is offline
    8th January 07
    Tinopai, New Zealand
    One suggestion; when you insert the pin, catch a piece of rubber cut from a wide elastic band (the one used for produce are great) by threading the pin though kilt, then through the top and bottom of the rubber and finally through the kilt again.
    That way, if the pin clasp comes undone, you are unlikely to loose the pin.
    Brian
  1. Attached to One Kilt.
    By Larry124 in forum General Kilt Talk
    Last Post: 3rd February 10, 01:23 AM
  2. The Scotland Kilt Company casual wool kilt review
    By CMcG in forum Traditional Kilt Wear
    Last Post: 17th November 09, 04:40 PM
  3. Replies: 39
    Last Post: 11th July 09, 07:32 PM
  4. DFW Kilt Night - Pink Boxer Soldier Kilt Dedication
    By attworth in forum Kilt Nights
    Last Post: 30th May 09, 04:13 AM
  5. No strings attached
    By The Wizard of BC in forum Professional Kiltmakers Hints and Tips
    Last Post: 19th March 07, 07:55 AM
