28th January 12, 05:36 PM
Kilt Pin Location
I have never worn a pin on any of my kilts. However, I received one as a gift that I like. I know the approximation location, but how do you determine the location you place your? How far in from from the edge and up from the hem?
28th January 12, 05:58 PM
Re: Kilt Pin Location
Some people say 3" in from the fringe and 3" up from the selvedge, which is more of a modern approach. I prefer 3" in, but 6-7" up, depending on the sett (I like to have the pin centered on a major stripe in the pattern).
Basically, do what you prefer. (although I'd steer clear of centering it in the middle of the apron )
ith:
28th January 12, 06:12 PM
 Originally Posted by artificer
I like to have the pin centered on a major stripe in the pattern.
A few inches in, centered on a major stripe works for me. How far up? I started low and am climbing--the more often I see it higher up, the more I like it. Put it where you like it, if you even choose to wear one.
Mister McGoo
28th January 12, 06:23 PM
Some of my kilt pins are a bit heavier than the normal type, and I have noticed that by moving them up, I don't have the pin swinging around so much. The apron stays in place because there's a weight on it, but placing the pin mid way between the knee and the hip also helps prevent snagging on ladies' ball gowns when dancing. Though I do have a couple of the typical claymore design, most of my kilt pins were not designed as such, which I find to be a bit more interesting.
EPITAPH: Decades from now, no one will know what my bank balance looked like, it won't matter to anyone what kind of car I drove, nor will anyone care what sort of house I lived in. But the world will be a different place, because I did something so mind bafflingly eccentric that my ruins have become a tourist attraction.
28th January 12, 06:26 PM
What the others said. I prefer to wear mine mid thigh
28th January 12, 07:15 PM
6" up, 2" in, regardless of the stripe
I wear pins that don't have straight lines, so it doesn't matter so much where they go.
--dbh
28th January 12, 10:34 PM
Never really thought about it...just pinned it on, looks to be 2" in and maybe 3" up. Don't over think these things.
Rondo
28th January 12, 10:52 PM
Check out how high Matt is wearing his pin in the picture (Post #1, Pic 1) on the the thread ...
http://www.xmarksthescot.com/forum/f...-supper-71643/
I wore mine at about the same place tonight at the Santa Fe Burns Party. All I had to do was tap my leg to check on my pin. Once, the pin had come undone and I stuck myself! But, I didn't lose my pin.
28th January 12, 11:17 PM
Mine are roughly 2" in and 4" up, depending on the stripe. I just stick them in wherever I think looks good.
29th January 12, 02:24 PM
I place mine,when not in uniform, in an area that does not encourage it to catch on things and I walk or brush up against stuff. I guess that means not right where my thigh is and above the knee. Fewer tears this way.
By Spartan Tartan in forum Kilt Advice
Last Post: 16th February 11, 04:55 AM
By Wolfhawk in forum Texas
Last Post: 31st May 09, 02:40 PM
By Oldhiker in forum Kilt Nights
Last Post: 29th November 08, 03:54 PM
By AlphaKilts in forum Comments and Suggestions
Last Post: 18th January 08, 07:17 PM
By pipebear333 in forum How to Accessorize your Kilt
Last Post: 7th March 07, 04:51 PM
