Results 1 to 10 of 13
    penannular brooch
    Has anybody ever used a penannular brooch for a kilt pin? I love the principle of the design and have fallen in love with the Raven Penannular Brooch
    http://www.gaelsong.com/Gcart/index....roductId=J6108
    but I'm afraid the circle will rotate around the pin and fall off. The brooch is awfully pricey, so it'd hurt to have it disappear on me.
    5th September 05
    Chicago
    That's nice...the folks who made my kilt pin do some simpler ones:
    http://www.ramshornstudio.com/retail/
    I'm waiting for a few of them to give as gifts this holiday.
    Best
    AA
    Yes, the larger Rams Horn penannular is really nice, too. It doesn't cost quite so much, which helps a bit, and the pin is a real pin which won't chew up fabric so much as the Raven Penannular will.
    13th March 05
    Orange County, CA., U.S.A.
    Quote Originally Posted by Alan H
    #1. How large is it?
    #2. How big of a hole is it going to make in the cloth?
    Iolaus, here's another link to a different vendor, with the size (1.5 inches)
    http://mystic-caravan.com/wellst.htm
    There's a choice of stones. I'm afraid that pin is going to dig a pretty good-sized hole, huh?. I might have to use the brooch for a fly plaid, which isn't something I'll wear very often.
    5th September 05
    Chicago
    Check out the Sghian Dubh on that mystic caravan website...
    Best
    AA
    Bob C's Avatar
    Bob C is offline Oops, it seems this member needs to update their email address
    3rd June 05
    The beautiful Catskill Mountains of Upstate New York
    I've gotta tell you, Alan - I wouldn't do it.
    There will be a gaping hole in your kilt. It seems your fear of losing the brooch would be well-founded, too.
    Virtus Ad Aethera Tendit
    18th November 05
    Fairfax City, VA
    I much prefer the ones that use a modern clasp just because the true broach leaves such a huge hole.
    17th August 05
    Littleton, CO
    Bear carries a pennanular brooch style kilt pin that looks very nice: anybody bought it?
    Bryan...it's too small for a fly plaid...
    21st February 04
    Michigan
    I use a penannular to pin my great kilt and never had a problem. I've also seen my pennanulars used as kilt pins, and a friend of mine uses a small brass penannular as a kilt pin. As long as you keep putting it through the same holes, it won't create gaps. But stay away from the ones with really wide pins, those should only be used for loose weave blankets, cloaks, etc. Also, when you pin it there should be cloth covering the entire pin within the diameter of the ring, so it can't slide. That helps keep it on. In addition, many brooces have finials that aren't flush with the body of the ring, which catches the pin if it does rotate.
    Ultimately it's up to you. I love the look of penannulars, and have done them in many styles. I'm putting a few up in the classified in the next few days.
