Results 1 to 10 of 28
Thread: Pin Problems
    Alaskan is offline Membership Revoked for repeated rule violations.
    21st March 04
    Hokkaido, Japan
    Pin Problems
    I've found that if I am walking quickly the latch on my kilt pin will open. If I jog or run my kilt pin will not only unlatch, but come out of the kilt completely. Has anyone else had this kind of problem? Does anyone know any way to remedy the situation? I am looking for remedies other than "Don't wear a kilt pin." or "Don't run."
    22nd January 04
    Charleston SC
    A lot of people on this board will tell you that you should not remove your kiltpin once you have it on your kilt.
    I agree to an extent, so what you should do it maybe put a dolop of hot glue on the latch of the pin. It dries quickly but make sure it dries before letting it rest back on the kilt! Hot glue from a hot glue gun will hold the latch securly but when and if you decide to remove the pin the glue is weak and rubbery enough that you can just pull the dried dolop off.
    Anyone else?
    Beannacht Dé,
    Hank
    "...it's the ocean following in our veins, cause its the salt thats in our tears..."
    Graham's Avatar
    Graham is offline Oops, it seems this member needs to update their email address
    4th February 04
    Tasmania, Australia
    I have the same problem, I've had a pin drop off more than once, they are quite unreliable.
    At work I go without, only wearing one on 'dress up' occassions.
    19th April 04
    Kanata ON
    Like Graham, I, too, only wear one for dress occasions, for the very reason you have stated.
    I am looking for a more spring like closure to ensure safety.
    Casey
    14th February 04
    Little Chute, Wisconsin
    I squeeze the latch a bit with a pliers. Just enough to make it snug. I've noticed that those types of latch are almost always a bit too sloppy. Another solution is a dab of rubber cement since it stays pliable and flexible when it sets.
    19th April 04
    Kanata ON
    Bubba,
    I have tried the plier method in the past and have found that it reduces the interety of the metal and leads to fatigue and failure sooner.
    Casey
    23rd January 04
    from England now in Ontario Canada
    Quote Originally Posted by bubba
    I have tryed this too, works so far, you can imagine on the Toronto night out, one of the guys says
    " anyone loose a kilt pin"? I look down and find mine has gone, it dropped off and fell in the pisser I picked it up with a paper towel and ran it under the hot water. pays to keep an eye on it evry few mins too.
    14th February 04
    Quote Originally Posted by Casey
    Bubba,
    Casey
    I haven't had any problem with the metal giving out. I only do it once, just enough to make it snug. After that no more is needed.
    21st March 04
    Hokkaido, Japan
    I was thinking about getting some superglue and putting a little bit in the latch and moving the latch back and fourth while it dries so that it doesn't get glued shut, but the latch gets tighter.
    15th April 04
    Bavaria, Germany
    Pinnage
    I use a bit of pencil eraser (rubber for you English speakers) stuck onto the end of the pin.
    cg
