 Bryan Proper Kilt Pin Placement 27th September 07, 04:13 PM
 ccga3359 I've heard 2" from the side,... 27th September 07, 04:19 PM
 Coemgen I keep mine about and inch or... 27th September 07, 05:22 PM
 James MacMillan Kokopelli - now there's a... 27th September 07, 05:55 PM
 Kilted Biker Newbie here, first post.
Why... 28th September 07, 07:10 PM
 James MacMillan If you pin through both... 28th September 07, 07:18 PM
 Kilted Biker I'll go move the pin... 28th September 07, 07:35 PM
 Jock Scot Welcome aboard.That is a very... 29th September 07, 02:40 AM
This has probably been done to death on the boards, but I have to ask. I've worn a kilt for a while now, not everyday like you lads and lassies, but on certain special occasions. I usually wear my kilt pin on the front apron only (naturally!) and anywhere from 1/4 to 1/3 up from the bottom.
My question is, is there a rule for the proper placement of the pin or is anywhere on the bottom half near the edge acceptable? And while we're at it, IS there a proper distance away from the frayed edge?
I've heard 2" from the side, 4" from the bottom. Then again it could depend on the size and shape. Go by eye.
27th September 07, 04:25 PM
This is kind of hart do explain, but ...
I stand with my legs about shoulder width apart. The pin goes dead center over the front of my right leg (adjusted slightly if there is a dominant thread near by - less than 1/4" - to center on). Bottom of the pin right at the top of the hollow before the top of the knee.
Adam
I'd post a pic, but I can't find a single one that shows a pin
27th September 07, 05:20 PM
OK - Since you asked, here is the definitive answer. All other answers are wrong!
Bottom of kilt pin is 3 11/16" from lower edge and exactly 3" from right edge, unless the pattern of the tartan makes the pin look weird, then start adding and subtracting 3/16" from right and bottom edges until it feels right........
Got it?
27th September 07, 07:09 PM
Got it?
Is that sarcasm I detect?
27th September 07, 07:45 PM
28th September 07, 01:07 AM
Good advice there.
28th September 07, 09:14 AM
I wear mine about 3" up and 3" in, at an intersection of lines.
Virtus Ad Aethera Tendit
28th September 07, 10:23 AM
Basically, unless you are wearing the kilt as part of a uniform, there are no regulations about the placement of the pin.
Basically, put it in the general region of the lower corner of the outer apron. Then just eyeball it to where it looks best based on the tartan.
Mine tend to be a few inches up from the botton and a couple from the side, adjusted based on the tartan.
I keep mine about and inch or so from each edge.
I think this is a case of "to each his own."
By apack in forum Professional Kiltmakers Hints and Tips
Last Post: 12th August 07, 11:05 PM
By I M Kilted! in forum How to Accessorize your Kilt
Last Post: 15th May 06, 08:45 AM
By MacConnachie in forum How to Accessorize your Kilt
Last Post: 28th December 05, 04:32 PM
By Geoduck in forum How to Accessorize your Kilt
Last Post: 16th February 05, 02:28 PM
By Dreadbelly in forum General Kilt Talk
Last Post: 6th September 04, 10:11 AM
