Results 1 to 10 of 10
    MacBean is offline Oops, it seems this member needs to update their email address
    21st October 09
    Valley Forge, PA (USA)
    Reworking a Hair Sporran
    I'd like some advice as to what's involved in swapping out the hair on a hair sporran.
    I recently bought a hair sporran for a boy. It has a lovely 6" wide silverplate cantle (which is why I bought it). The hair is only 15"; too short by far. It's not one of the hair sporrans that opens, but does have the little pouch in the back.
    In reading up on how to make a hair sporran, it seems it is sewn to the front, which means I'd have to disassemble the stitched binding around the edge to get at the front.
    So some questions: is 6" wide a reasonable cantle size? Has anyone reworked a sporran this way? What do I need to sew leather (I have a sewing machine, but am not sure it will handle leather)? Recommendations?
    3rd March 10
    43*N 88*W
    your best bet would be to remove the cantle and tassels and simply have a new body made. Save the original as well for posterity and collector's value.
    19th October 09
    South Queensferry, Scotland
    Cantle size
    I can only answer the first question. I have three adult sporran cantles that are only 5 and 3/4 inches wide, and three that are just over 6 inches wide. They date from the 1940s to the 1980s although two of the smaller ones are of 18th century design.
    It's coming yet for a' that,
    21st October 09
    So do you make hair sporrans?
    Was your recommendation in part based on a suggestion not to dissassemble an old sporran worth keeping, or perhaps that old leather is likely to be brittle?
    I'd have thought that the front leather would come right off once the binding was removed. Perhaps I could replace it alone?
    3rd March 10
    43*N 88*W
    Quote Originally Posted by MacBean View Post
    My recommendation is based on a few things:
    1) we don't know how the face is attached to the back
    - it would be a pity to dissect a vintage piece only to find that it's glued on the inner faces.
    2) depending on the leather, a 'recrafter' would have to be VERY careful about the sewn edge and re-sewing the trim. If the leather is older and brittle, considerable damage could be done to an area that's already weaker from the original stitch holes.
    3) Simple cost. You're probably going to pay MORE to have the piece disassembled than you'd pay to have a new body put on your original cantle.
    4) I personally would ALWAYS prefer to keep old objects intact, or at least if they are changed, make sure the changes are reversible. You can swap bodies and keep the original, and that way if you ever choose to sell it, you can offer both the original and updated bodies.
    ith:
    12th December 10
    Fairbanks, Alaska
    *** on what artificer said. All new vegetable tanned leather to make a complete sporran is $20, maybe $30; the new longer hair is a wash either way.
    If it was me doing it I would rather not take the time to take the old one apart, good chance of wrecking it anyway. New leather you can select your self and not have to be like a museum curator when you are stitching it back together.
    Cool cantle though, I see the appeal.
    M2c,
    S
    I've done a load of cantle switching over the years.
    My advice would be to pick up a vintage full length horsehair sporran on Ebay and put your nice vintage cantle on it.
    A 6" wide cantle is fairly standard for 20th century adult sporrans. I've had a number of cantles over the years from the 1900-1930 period and they're usually that wide.
    In the 19th century cantles tended to be somewhat wider. I just sold a 19th century cantle that's around 6 1/2" wide.
    I actually have a very nice, new condition, full size white horsehair sporran made by Janet Eaglton that I could sell you. I was thinking of keeping it but I'll probably never end up wearing it. Your cantle should pop right on.
    21st October 09
    Super advice all around. You guys continue to amaze me!
    OCRichard, a PM is in preparation...thanks
    21st October 09
    Swapping tassle cones on a hair sporran
    I've a potential opportunity of swapping out the sporran for a newer, and longer one. The one thing I'm not too sure on is the tassle cones and chains, as the old ones are really lovely. Has anyone attempted swapping out cones and chains?
    7th July 09
    Melbourne,Victoria Australia
    The cones and chains may be somewhat fiddly to deconstruct. Sometimes the cones are stuck to the horsehair with a gum substance. I have found heating the cones with a hair dyer has helped loosen the gum to enable removal of the cone.
    As for the chains being removed, maybe be a problem as the only ones I have seen is where the chain is sewn into the horsehair and then glued. I had some old wrecked tassels and took one apart and I would say that if you want to use the original chain, then you will have to replace the horse hair.
    All in all I think you could easily remove the cones but try to match/ substitute the tassel chains
  1. Goat Hair Sporran-Help
    By dbi in forum General Kilt Talk
    Last Post: 12th October 10, 02:58 PM
  2. Conditioning Sporran Fur/Hair
    By Dram in forum DIY Showroom
    Last Post: 27th February 10, 11:02 AM
  3. Hair Sporran
    By Italian Black in forum How to Accessorize your Kilt
    Last Post: 7th March 09, 05:04 AM
  4. DIY long hair sporran
    By LadyGriffin in forum DIY Showroom
    Last Post: 12th April 07, 05:53 AM
  5. Horse hair sporran
    By navycb in forum Kilt Advice
    Last Post: 17th January 07, 06:19 PM
