5th February 10, 03:33 AM
Sgian Hallmark help?
So in the course of this thread ...
http://www.xmarksthescot.com/forum/a...889/index.html
Chas asked about the hallmarks, so I got out the loupe and found several. On the tip of the sheath there are 2 shield shaped marks, a rampant lion next to one which looks like a castle or keep? On the silver at the top of the sheath, I found those 2 followed by one with a script "C" followed by by one which was too faint to make out. Any ideas?
BTW, I spent some time polishing last night and both pieces came out stunning! I'm sick, so I went to bed without posting the "after" pic. Maybe tonight if I get a chance.
5th February 10, 03:48 AM
A good reference is British hallmarks
The castle mark is probably Edinburgh
5th February 10, 03:57 AM
Yes probably Edinburgh(it might be Exeter or Newcastle, for various reasons I doubt it though) and IF the "C" is in a square shield shape then Edinburgh 1909 and the mark that you can't make out is probably the makers mark.GO STEADY WITH THE POLISHING!!!!!!!!
5th February 10, 10:22 AM
Now, it looks like by that document that the C within a square is 1977, the third year the common date stamp was used. I do not have it in front of me, but I suspect, imperfect memory aside, that this may be it. The script matches. I will have to check it again when I get home and report back. Definately Edinburgh. I wish the makers mark was clear. It would be nice to know who made it. I will have to look at that more closely as well, against some pictures. Maybe I can figure it out.
5th February 10, 10:30 AM
Actually, 1977 might explain the blade as well. It's only mark is "stainless steel" which made me question whether it had replaced at some point, but if it was made in 1977, that would be consistent. I need to look at it again....
5th February 10, 11:01 AM
If my memory serves me correctly and I have not time to look it up. If it is Edinburgh(castle tower), pre 1975, one of the marks should be a thistle. Post 1975 Edinburgh(castle tower) there should be a rampant lion and no thistle. Hope this, er, well, helps!
5th February 10, 11:23 AM
That fits as well. I have, from left to right, rampant lion, castle tower, "C", then a faint mark I can't make out. That matches the timeframes from the above document as well. Your memory is better than you let on! I think this may be dated to Edinburgh, 1977, in the end...
5th February 10, 07:47 PM
WOW! I'm floored, I looked at this sgian against this..and I see an "R" inside a faint oval, and possibly an "A" next to it, depending on how I hold the light. I may have a piece by Robert Allison, who did make some findings for dirks and sgians. Here's the reference....
http://www.silvermakersmarks.co.uk/M...nburgh-RT.html
This may be pretty cool....
If you look down to the r's , the "RA" with the darker background is identical, with the "A" very faint on mine. I wish I could get a picture of this. I am a fan of his work, and am very excited by this find!
5th February 10, 08:13 PM
cThis is it....
http://www.silvercollection.it/ENGLI...R.html#1071ING
Scroll down to the "Robert Allison" section and that is a match, except the "A" is woirn, but there.
By Chas in forum DIY Showroom
Last Post: 25th August 09, 05:04 AM
By Geoff Withnell in forum How to Accessorize your Kilt
Last Post: 3rd February 09, 08:15 PM
By Tartan Hiker in forum DIY Showroom
Last Post: 31st January 09, 08:27 PM
By Phogfan86 in forum Miscellaneous Forum
Last Post: 22nd January 09, 05:11 PM
