Results 1 to 9 of 9
Thread: Sporran Hangers
    17th August 09
    Bath, Maine USA
    Sporran Hangers
    My sporran hangers tend to slide to the belt buckle and let the sporran hang lower then it should. I'm starting to think I should rip out half the chain from each hanger. was I supposed to do that or is there something I'm missing that would stop the hangers from sliding on the belt?
    25th March 08
    Louisville, Kentucky
    You could try using an old stand-by: the sporran strap! You won't have any problems with one, plus you'll look a whole lot nicer IMHO. Those hangers have way too much hardware, which competes with the sporran for attention and becomes an eyesore.
    17th December 07
    Staunton, Va
    I know there is a school of thought that runs something like "sporran chains will damage your kilt" and, if that's true, then it would seem to me that all of the hardware on sporran hangers would/could also damage the fabric on the outer apron of one's kilt. That being the case, I'd row in with Sandy and second his suggestion that a leather sporran strap is the best way to go.
    22nd November 07
    US
    I think it was decided, by several members, that the type of chain that was doing the damage to the kilts is the cheaper chains which are not welded at each link. I have a few of these types that came with my cheap sporrans, and they do have a rough, sharp edge at the end of each link where the ends of the wire they are made from is cut.
    I decided to replace them with two dog collar, choke chains that are welded with no rough edges on any of the links, and held together with a small, split key chain ring at the back.
    27th January 05
    Jefferson, Georgia, USA
    You do need to remove the excess links from the hangers so they hang at the desired level directly above the sporran. Chain hangers will come with extra chain to fit Gents of many different sizes.
    You could also scrap the chain altogether and go with a hanger like this
    8th February 04
    1 Thread(s)
    The reason many men go with the Sporran Hangers INSTEAD of a sporran chain or sporran strap is that they're a 'man of considerable subatance'. WHile that MAY NOT be the case here, I simply point out that not all men can wear a sporran chain or strap without it 'underlining the belly'. Sporran hangers negate the need for a strap/chain and therefore leave a much more 'clean' appearance to the man.
    Tiny.. remove the links of the chain to get it to hang at the correct spot. The top of the sporran should be about 3 fingers BREADTH from the bottom of the buckle. Alternatively, look into sporran hangers like Cavscout pointed out above or ones like these:
    25th November 09
    Lomita, CA (via Boston, MA)
    Quote Originally Posted by cavscout View Post
    I do not wear these all the time, but particularly when participating in active stuff these sporran hangers are great. I own a pair of these exact ones and they are really good and extremely well made.
    17th August 09
    Bath, Maine USA
    currently i do tip the scales a bit higher then some, and as such the standard sporran strap/chain belt tends to emphasize my dunlop syndrom. the kilt does a fine job of concealing my ailment but add the chain and it brings back all that the kilt hides.
    I took out 5 links from the hangers and the sporran hangs much better now. still I will be looking to order a nicer set of hangers soon.
    6th July 08
    Montgomery Village, Maryland, near Washington, District of Columbia
    Quote Originally Posted by Tiny View Post
    I really like these: http://www.oconeeleatherworks.com/MiscAcces.htm
    Good heavy duty hardware and leather.
    Geoff Withnell
    Geoff Withnell
  1. New sporran hangers
    By sathor in forum How to Accessorize your Kilt
    Last Post: 16th May 09, 08:29 PM
  2. Sporran Chain hangers...
    By Dan R Porter in forum How to Accessorize your Kilt
    Last Post: 4th April 09, 06:04 AM
  3. Sporran Hangers
    By Madd Celt in forum DIY Showroom
    Last Post: 7th January 09, 07:40 PM
  4. Sporran hangers
    By usary in forum How to Accessorize your Kilt
    Last Post: 1st December 08, 08:04 PM
  5. Sporran Hangers
    By Tiran in forum How to Accessorize your Kilt
    Last Post: 20th November 07, 06:34 AM
