Results 1 to 10 of 20
    3rd May 06
    Minneapolis, MN
    sporran placement!
    aloha, I just wore my very unique kilted outfit to Prom last night. I danced and walked around until from 8pm to 3am and then went out for an early morning dinner; about halfway through the sporran package was hurting my package!
    Ouch it hurts! I had a two cameras and a money clip and id cards etc inside, so I don't think it was that heavy...mabye I am wearing it wrong...
    What is the correct placement for the sporran?
    29th January 06
    Asheville, NC
    Most will tell you a hand-width below the belt. Practically speaking, if you load one up the way you descibe you'd better tighten up the strap so that the sporran is hard up against the belt buckle. After walking a bit it will edge downward to its final resting place, which should certainly be well above your sensitive anatomy.
    Comfort is key. If it feels wrong, it probably is!
    14th September 05
    Space Coast, FL
    2 Thread(s)
    Ouch! Methinks it was too well loaded, and as TH said, a might too low. I have never had that problem and it must be uncomfortable. Are you sure it was not all the kilt checks that caused the tenderness??
    3rd May 06
    Minneapolis, MN
    Quote Originally Posted by KiltedCodeWarrior
    Ouch! yep, it hurts...sorta like a very uncomfortable and painful ache...not cool!
    I was dancing for about 3 hours, so it might be the weight over the amount of time that was making it painful or perhaps it was too low.
    Does the sporran rest above or infront of the "package"?
    What is a "kilt check"?
    23rd January 04
    You must have packed the sporran to the max.
    3rd May 06
    Minneapolis, MN
    Quote Originally Posted by Raphael
    mabye, but it did'nt look packed. The two cameras were about 3.5"x2"x1" and my money clip is a standard size, I placed the cameras side by side vertically inside the sporran and I put the money clip and my cards on top.
    Southern Breeze's Avatar
    Southern Breeze is offline Oops, it seems this member needs to update their email address
    28th August 05
    Chatsworth Georgia, USA
    Quote Originally Posted by I M Kilted!
    Ah, the innocence of youth.
    3rd May 06
    Minneapolis, MN
    Quote Originally Posted by Southern Breeze
    just joking!
    Is it a kilt lift or is it when someone runs into you on purpose to feel/see the kilt...i've had both...
    Kilted KT is offline Membership Revoked for repeated rule violations.
    4th March 06
    A long time ago in a kilt far, far away
    Quote Originally Posted by Tartan Hiker
    yup, he ain't lyin...closer to the buckle means less abuse...
    28th August 05
    Smile
    just joking!
    I was 99% certain that was the case.
