8th September 07, 12:25 PM
Steam cleaner
As I'm planning on reupholstering my chesterfield and chairs it suddenly occured to me that a portable steam cleaner would help the (wife chose) tapestry fabric lay properly. I hen recalled people such as River Kilt uses a steamer to straighten out his pleats. Are the two animals on in the same and if not can a steam cleaner be used to straighten pleats in a pinch. No doubt a cleaner would be a better alternative to throwing my canvas an PV kilts in the washing MacHine. Thoughts, observances, practices?
8th September 07, 02:08 PM
What kind of steam cleaner? I've found a steamer helps straighten pleats, but I can't imagine using an upholstery cleaner on my kilts.
8th September 07, 05:08 PM
Grant, do a quick search for "steam" and "Home Depot," and if I remember correctly the thread was started by Jimmy Carbomb. There should be a make and/or model there.
8th September 07, 05:57 PM
Thanks gary, here is the link to that thread for those others wondering.
8th September 07, 07:08 PM
A "Steam Cleaner" and a "Fabric Steamer" are two totally different animals.
A "Steam Cleaner" such as that used on rugs and upholstery is a marriage between a water heater/sprayer unit and a wet-dry vac. You spray hot, soapy water into your rug and then vacuum it up.
A "Fabric Steamer" actually generates live steam by boiling water and directing the steam towards the fabric.
I would not advocate using a Steam Cleaner on your kilts. A Fabric Steamer however is the perfect touch-up tool. I tell my customers to find a small, portable Steamer and use it to relax wrinkles from their pleats, to freshen their kilts between washing, and to remove odors such a tobacco smoke.
8th September 07, 07:14 PM
A
Thanks Steve. I guess what i was asking is can I use one for the other. Steam cleaner - no. Could I use a fabric steamer on the couch, would it even be worth it?
8th September 07, 10:57 PM
Actually, yes. Unless your Chesterfield is dirty from sitting on it after doing the gardening or changing the oil of your car. The thing that makes things smell musty and foul is bacteria. Steam is a very good killer of those little buggers and will leave fabrics fresh smelling.
So go ahead, lay your kilt out on the sofa and kill two bacteria with one pass.
De-wrinkle your kilt and freshen your couch at the same time. The perfect bachelor answer to both problems.
Last Post: 29th May 07, 02:03 PM
Last Post: 25th September 06, 06:28 PM
By ronstew in forum Miscellaneous Forum
Last Post: 14th April 06, 01:51 AM
By Doc Hudson in forum How to Accessorize your Kilt
Last Post: 24th July 05, 08:39 PM
By Dreadbelly in forum General Kilt Talk
Last Post: 6th September 04, 05:26 PM
