Results 1 to 10 of 13
    Kerrville, Texas
    8 Post(s)
    Is there any hope or help for cheap hose?
    I have a pair of cheap cream kilt hose that's a blend of wool/acrylic/nylon/polyester. It was the first pair of kilt hose I bought, before I discovered the wonders of thicker knitted colored hose with a higher wool content.
    I know a lot of people refuse to wear cream or white hose, and stick only to real colors. I am kind of moving that direction myself, but would perhaps like to have the one set of cream hose in reserve, in case I ever feel it would be appropriate with something.
    But my complaints about this pair of hose are that they're so thin, they look like glorified gym socks (as someone else put it in another thread). The ribbing on the leg doesn't really stand out. And the decorative stuff on the turn-down lays so flat it's not noticeable. They just look like a pair of long white socks folded over, if you see them from more than two feet away. But worst of all, they're so thin that they 'print' the shape of the garter around my leg (especially the hooks where the elastic connect), and you can see the shadow of the flashes through the turn-down. The material feels very elastic and just doesn't have any body or bulk to it.
    I didn't really notice it until I started wearing higher quality hose that seemed to have more bulk to them, especially at the tops. I have skinny bird-legs, so any help I can get to make my calves look more manly would be good.
    So this pair really doesn't get worn any more. But I hate to throw them out.
    Aside from spending big bucks on hose cuffs to cover the tops up, is there anything you'd recommend? I was thinking that I could maybe take some 1/4" thick batting or thin foam and cut it into strips that could go inside the turn-down. This might give it some bulk and hide the printing/shadowing of the garters and flashes. But I don't know if it would just end up looking stupid. Like padding a bra or something.
    Is there any way to save these hose and make them look better at the tops without spending an arm and a leg?
    bricelythgoe is offline Membership Revoked for repeated rule violations.
    7th January 09
    Where did you get these hose from?
    30th June 06
    Lotusland, Canada
    PM sent.
    Gentleman of Substance
    Kerrville, Texas
    8 Post(s)
    Quote Originally Posted by bricekolob View Post
    They're the ones Rocky sells for $9.99 a pair. I don't wanna knock him or his products, though (I'm not even sure who the manufacturer is). There is nothing "wrong" with the hose; they're worth what I paid for 'em. It just turns out that I prefer thicker hose.
    7th May 09
    Oslo, Norway
    Many people will like thin hose, but if you don't I can't see what you can do other than buy thicker hose... To me, the bottom line is "will I wear this", and if the answer is "in a pinch" then I donate the item to charity and move on.
    Vin gardu pro la sciuroj!
    22nd March 09
    Savannah, GA USA
    I'm not sure you'll get a satisfactory result trying to "rig" something up... they are what they are. I suggest you set these hose aside for hot weather use and save up for some hose with substance.
    I recommend Big Mikey.
    Kerrville, Texas
    8 Post(s)
    Looks like Big Mikey's hose cuffs may be the answer. Thanks guys!
    19th March 09
    Dallas, TX [N 32° 51.288 W 096° 45.978]
    Additional options: If you're just concerned about colour, maybe you can dye them. Ritts (?) dye can be found at most supermarkets and only costs a buck or so.
    If they're just really too thin to be worn well, could you use them as hose liners on really cold days? I.e. wear them under your normal hose to add some extra warmth and reduce any irritation your nice woolies might cause.
    elim
    30th September 08
    Cypress, Texas
    If you're wanting help to bulk up your calf, you might consider wearing piper hose, which are longer and fold over multiple times. I've gotten to where I wear them almost all the time when kilted.
    I know the Scottish Tartans Museum giftshop and the College of Piping both sell them in colors as well...
  1. I hope he joins
    By kiltedinUSMC in forum Contemporary Kilt Wear
    Last Post: 21st June 08, 12:30 PM
  2. Cool weather kilt hose on the cheap.
    By kevinkinney in forum DIY Showroom
    Last Post: 27th April 07, 04:49 PM
  3. Cheap, practical hose for TIGHT budgets
    By MacWage in forum How to Accessorize your Kilt
    Last Post: 23rd December 06, 11:21 PM
  4. Inexpensive (not cheap) wool kilt hose -- Where to find?
    By SSgt Baloo in forum How to Accessorize your Kilt
    Last Post: 30th September 06, 11:51 PM
  5. Hope for our new kitten
    By beerbecue in forum Miscellaneous Forum
    Last Post: 30th June 06, 01:16 PM
