 threebanger Think I can get away with... 22nd November 09, 08:36 PM
 ccga3359 Hey if I can get away with a... 22nd November 09, 08:41 PM
 dfmacliam my thought is it would be a... 22nd November 09, 08:43 PM
 MacMillan of Rathdown It may, or may not, be too... 22nd November 09, 09:07 PM
 The Barry It might very well look a bit... 22nd November 09, 11:44 PM
 MacKay71 Give it a try! 23rd November 09, 12:12 AM
 Jock Scot Give it a try, but I suspect... 23rd November 09, 03:38 AM
 threebanger Yeah, the bulk/diameter of... 23rd November 09, 09:31 PM
 threebanger I actually didn't fare too... 2nd December 09, 10:59 AM
 graham_s To be honest, I don't think... 2nd December 09, 11:19 AM
 WClarkB take the knife and grind it... 5th December 09, 02:36 PM
 Jack Daw Do it. 6th December 09, 02:16 PM
 KiltedMariner Perhaps instead of your... 6th December 09, 03:52 PM
Think I can get away with this?
I recently dug out an old knife I had as a kid. It's only slightly larger than my sgian dhub...I wonder how it will fit in the top of my hose!
"...when People are universally ignorant, and debauchd in their Manners, they will sink under their own weight without the Aid of foreign Invaders."
Samuel Adams
Hey if I can get away with a rubber chicken sporran...
You could but it looks as though it may be a little heavy. Perhaps a different sheath that straps to the calf (if this is the case) and nix the strap around the pommel.
Truth be told there is no kilt police but if they flash their badges and ask, you didn't hear from me and you haven't seen me either. Capice?
my thought is it would be a bit top heavy, and hard to keep in your hose.. just an opinion
– Robert Louis Stevenson
22nd November 09, 08:53 PM
My thoughts as well.
It may, or may not, be too heavy. If the overall length of the knife is about 6.5-6.75 inches it will possibly work. To try it, first make a sheath out of a piece of thin cardboard, like the kind that comes with a new shirt. Then, with not more than half the hilt above the top of your sock, walk around for an hour or so, go up and down some stairs, etc. If it is too heavy, you have two choices: buy a proper sgian dubh, or shave some of the horn off the back of the hilt and hope it will work.
Unless you really like tinkering (and don't mind potentially buggering up your sheath knife) I'd suggest you save the pennies and by a decent sgian dubh. It's your call.
It might very well look a bit odd. Only one way to truly tell. Give it a go and see how it looks.
The Barry
Scott D McKay
23rd November 09, 03:30 AM
You might just have to bury it a little deeper than a sgian dubh. If the weight is not an issue and you use it about as often as the average sgian dubh, then you'll rarely have cause for it to worry you.
Give it a try, but I suspect that you may find it too bulky.
23rd November 09, 05:27 AM
Yes I feel the same way.
Best,
Robert
Robert Amyot-MacKinnon
